Fuel problem...Help! Evap pipe quick disconnect?
Old Jan 25, 2011 | 07:47 PM
blackula 99's Avatar
blackula 99
Default Fuel problem...Help! Evap pipe quick disconnect?
Right above my passenger fuel tank I have what it looks like to be a fuel evap pipe that I need to disconnect{bad tank} Anybody know how this disconnects?Its the black pipe next to the blue filler neck.
Old Jan 25, 2011 | 07:54 PM
pcolt94's Avatar
pcolt94
I'll bet the C5 guys in the C5 Forum would know.
Old Jan 25, 2011 | 09:13 PM
blackula 99
Default oops..
My bad....ya it might be a bit better in the c5 category
Old Jan 27, 2011 | 12:08 PM
SunCr's Avatar
SunCr
Assuming it's a standard GM quick connect fuel line, your local Discounter (AutoZone, NAPA, etc) sells the plastic tool(s) that you need to take it apart - they're a couple of Bucks. Simply insert the right size tool over the line; push it into the fitting and pull it apart. With fuel lines, always make sure to relieve pressure first.
To Fuel problem...Help! Evap pipe quick disconnect?
