84 Headlight problems
Old Jan 26, 2011 | 06:12 PM
danvetman's Avatar
danvetman
Default 84 Headlight problems
I had my car painted a while back and the painter took the headlights apart to paint them and did not get them back in the same way they came out. The gears were bad in one of them and I got new ones and put them in with the help of some stickies. But when I put everything back together and tried the lights, the motor turns the lights on but they slam into the stops on both sides. I think the motor gears on not in the correct sequence with the light bracket. When I put them on, I had them set what looked to be in the correct closed position, but when I turn the lights on, the motor turns the lights and the stop pins hit on the stop marks very hard but the headlights are not all the way up. I am very frustrated, can anyone help me out. These lights are a little different than 88 and up.
Old Jan 26, 2011 | 07:57 PM
oldalaskaman's Avatar
oldalaskaman
the short version of this is if one of them works, use the **** and manually adjust the other one to match the position its at. the other version is to open the hood , turn the lights on, and use the ***** to manually open them both to the same position, or all the way open and firm to the stops. more than this requires taking them back apart. , hope this helps.
Old Jan 26, 2011 | 08:29 PM
danvetman's Avatar
danvetman
They both are doing the same thing. I took them back out again and the small gears are chewed up on both sides. The big gears are ok. Now I have to order two small gears. I just installed one new one. Once I get the new gears back in there, I am afraid the same thing is going to happen again.
Old Jan 26, 2011 | 08:59 PM
oldalaskaman
you're small gears may have been bad also, make sure to lube them .
Old Jan 26, 2011 | 09:08 PM
danvetman's Avatar
danvetman
One of the gears was brand new. I had just replaced it and it had plenty of lube on it. Something else is wrong causing them to strip out and not open properly.
Old Jan 26, 2011 | 09:22 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Never been inside one, but there are limit switches. If these are not functioning correctly, bad things can happen.
Maybe a closer look inside is in order.
Old Jan 26, 2011 | 09:34 PM
danvetman's Avatar
danvetman
One important thing I forgot to mention is that they are binding when trying to open and close. I don't know how I forgot to put that in there but I did. Must be another senior moment. But they need a helping hand. Don't know why they are binding.
Old Jan 27, 2011 | 09:50 AM
oldalaskaman
I went thru all of these same issues with my old style"87" lights , upgraded to the later style, nomo issues.
Old Jan 27, 2011 | 10:04 AM
danvetman's Avatar
danvetman
When I have the lights closed in the off position in the correct place, the adjusting **** is very tight in one direction. I was wondering if this is causing the binding in some way? Is the **** suppose to be tight or is it suppose the be able to be turned freely in both directions? I keep thinking that spring is set too tight to begin with and I need to rotate it before installing the motor so that it turns freely in both directions. Any thoughts on this?
I do appreciate the help I'm getting.
Old Jan 27, 2011 | 11:10 AM
oldalaskaman
my old ones did that binding , they need to be easy to adjust , both directions.
Old Jan 27, 2011 | 11:25 AM
danvetman's Avatar
danvetman
Thanks OldAlaskaman from an old Okie. I am going to play around with it some more and see what happens while I'm waiting on the gears. If I ruin these gears, I will head towards a new direction probably where you went to.
Thanks again for your help. If I get it figured out, I will let folks know on here so maybe someone else won't go through the same thing again.
Old Jan 27, 2011 | 04:45 PM
oldalaskaman
the trick to getting them not to bind is to put the gears in and before you put the cover on rotate them to get the gears good and meshed, put the cover on and rotate them again. If they tighten up take the cover off and look. Sometimes the bushings arent all the way seated
To 84 Headlight problems
