wheel expert needed
Old Apr 10, 2002 | 09:08 PM
ittlfly's Avatar
ittlfly
Default wheel expert needed
Hey Guys...does anyone know if I can run Y2K C5 wheels on my 92? I understand that the fronts are 17x8.5. I have the ZR-1 13" brakes on my front. I am concerned about any clearance problems I might encounter with calipers etc...
Old Apr 10, 2002 | 09:40 PM
Q1KSLVR's Avatar
Q1KSLVR
Default Re: wheel expert needed (ittlfly)
I've seen a few cars with C5 wheels and I know they will fit. There are even a few members here who have them.
What I want to know is, why would you want to take off a 9.5 inch wheel, to put on an 8.5?
Maybe if you used rear wheels (18x9.5) that would be REAL trick!
Save the Wave! :cool:
Old Apr 10, 2002 | 10:30 PM
ittlfly's Avatar
ittlfly
Yea, your probably right about the 18x9.5. on all 4's. I like the looks of the C5 Y2K open wheel look. I thought that the 17"/18" combo would give a slight rake to the car which might look good. Maybe I'll give it a little more thought.
Old Apr 10, 2002 | 10:44 PM
Q1KSLVR's Avatar
Q1KSLVR
As long as all the tires are the same size because of the ABS. If the tires are going different speeds, it will set ABS codes.
SAVE THE WAVE! :cool:
To wheel expert needed
