ICM failure again!!
Old Jul 1, 2011 | 12:04 AM
gerardvg's Avatar
gerardvg
Hi Helphos
Some time i had this issue back fire no power, would idle ok but engine shaked,backfired when accelerating.
Turned out to be a injector connector. found it by starting engine running for a few secs and found one cylinder cold on the header.
Hope this info helps
Old Jul 1, 2011 | 07:17 AM
helphos's Avatar
helphos
Default Connector wire
Originally Posted by gerardvg
Hi Helphos
Thanks for the info! How far upstream did you have to go with replacing the connector? I'll investigate the connectors this weekend.
Happy 4th of July Weekend!
Paul
Old Jul 1, 2011 | 10:50 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Originally Posted by helphos
I'm getting no codes! I am using a scan tool (not the paperclip method) and I would expect to see at least as many codes a s the paper clip would show. It's very frustrating- car runs poorly and backfires and scan tool shows 'no codes!'
I did check ICM - testing A and D (on the ICM plug) with a multimeter to ground, and both came up at 11.6 volts. I have not done the AC voltaqe test with a helper cranking the engine. I'll try that tonight.
I've replaced plugs and wires AND Coil! I'm doing everything I can to make sure that if I get down to replacing the Opti, then that will in fact get me running again.
I've visually checked hoses for vacuum leaks, and see none.
Please tell me it's not the dreaded Optispark!
No codes = ICM or the connector at the intake. I'd kinda bend the pins on the male side to see if you can get a better electrical connection.
Do the same on the ICM connector. If that does not help then replace the ICM.
Almost always the opti throws a code.
Old Jul 1, 2011 | 12:28 PM
scotth48's Avatar
scotth48
When I replaced ICM and coil I used a thicker nylon washer to get it away from the head on each side of the bolt to lessen heat transfer to the bracket and used plenty of the compound between heat sink and the ICM. Seems to be working ok for 2 years. When I got the car it did not have the coil and ICM. I had a hard time finding the bracket but once I got it and heat sink I installed it as to factory spec, but lasted about 2 months before fixing it like I have it now.
Old Jul 1, 2011 | 08:48 PM
helphos's Avatar
helphos
Default Suspicious ICM
Thanks for the advice. The ICM isn't cheap, but it's better than buying an Opti. The notion that the Opti should throw a code tracks with my thinking and my thought that most Opti problems will shut down your engine far from home. The idea that the ICM is sensifive to heat ties in with the fact that my engine runs strong for a couple of minutes first thing in the morning and then craps out. I can't imagine the opti behaving like that (but I could be wrong!).
Anyway the ICM is 'only' $100 or so, and if it would make my car run like the old days, it would be worth it.
It looks like I might not have to remove the whole coil-ICM assembly to get the ICM out. That would be nice.
Stay tuned!
Paul
