MAP testing 96 corvette
Old Feb 8, 2011 | 05:06 PM
terrycoxusa's Avatar
terrycoxusa
Default MAP testing 96 corvette
My engine is getting a po171 fault code, lean fuel bank 1, the MAP will briefly read the correct Manifold vaccum when started and then starts reading about 8 inches lower than a gauge reading. eg the manifold vacuum is 16-17 inches by gauge, the MAP reading is 10 inches per the OBD scanner. What is the test procedure to check a map, and what is your collective opinion of this? Thanks,
