cam shafts
Old Feb 14, 2011 | 09:03 AM
Crowhater's Avatar
Crowhater
Default cam shafts
I am going to change out my factory TPI intake for one that I have ported out in a couple of weeks. While I have it off I thought about changing Camshafts. Will I gain much with a cam change? I do not have the factory motor in my 1990 c4 it has been changed to a ZZ4. If I do change cams what would be the best cam for my car? I have a 2800rpm stall, 307 rear end, etc.
Old Feb 14, 2011 | 09:31 AM
rodj's Avatar
rodj
Originally Posted by Crowhater
engine it has been changed to a ZZ4.
Does it have a ZZ4 cam in it ?
Old Feb 14, 2011 | 09:33 AM
Crowhater's Avatar
Crowhater
I do not know, the car had a ZZ4 motor in it when I bought the car so I guess it does.
Old Feb 14, 2011 | 07:03 PM
rodj's Avatar
rodj
Need to find out what cam you have at present.
Because the ZZ4 engine is such a good buy, cost wise ;
many buy one and then swap in a cam of their own choice
Also given that a ZZ4 looks identical to a '90 engine ; how do you know you actually have a ZZ4 installed
What numbers on block?
Old Feb 14, 2011 | 07:05 PM
Crowhater's Avatar
Crowhater
It says the zz4 has 1.5 rockers should I just forget the cam swap and get 1.6 rocker?
Old Feb 14, 2011 | 08:57 PM
THE 383 admiral's Avatar
THE 383 admiral
it's a close call to use 1.6 rockers on ZZ4 springs
your final lift will be .504 .540 you may have coil bind
they claim a max .550 lift that's pushing them especially if there older
Old Feb 14, 2011 | 09:02 PM
rodj's Avatar
rodj
ZZ4 /LT4 springs are only factory rated to .525
http://www.superchevyperformance.com...p/12495494.htm
http://www.gmpartsdirect.com/performance_part
s/store/catalog/Product.jhtmlPRODID=742&CATID=734.html
http://www.jegs.com/i/GM-Performance...oductId=761647
Some say they are safe to .530
Old Feb 14, 2011 | 09:10 PM
THE 383 admiral
I saw 3 ratings
if .525 -.530 is max... then No way can you use 1.6 rockers
Crowhater's Avatar
Crowhater
Guy please explain? Do I need to change my springs to run the 1.6 rockers? If so what springs do I need and what seat pressure do I set them up at? My ZZ4 engine has about 30k miles on it.
Old Feb 14, 2011 | 09:17 PM
THE 383 admiral
yes upgrade your springs if you want to install 1.6 rocker ratio
I would use something close to compcams 986 springs
132 seat@ 1.75<> 293 open @1.25
Old Feb 14, 2011 | 09:32 PM
Crowhater's Avatar
Crowhater
Ok that is fine, what springs do I need and what do I set them up at? Is all of this worth the gain from the 1.6 rockers?
Thank you for the help!
Old Feb 14, 2011 | 09:35 PM
THE 383 admiral
I installed 1.6 rockers on my buddy's stock LT1
you could feel a little Difference!!!! but no it would not be worth the effort
Old Feb 14, 2011 | 09:44 PM
THE 383 admiral
I would install gears 3:50 - 3:73 range
Old Feb 14, 2011 | 09:46 PM
Crowhater's Avatar
Crowhater
You would do this instead of stroking the motor to 383 when it gets tired.
Old Feb 14, 2011 | 09:53 PM
THE 383 admiral
you did not mention changing the engine... if you have a TPI setup no I would not
stroke to a 383.. the intake is all wrong unless you change to a mini or stealth ram
injectors and endless mods
Old Feb 15, 2011 | 12:46 AM
rodj's Avatar
rodj
You still haven't established if
1. you actually have a ZZ4 engine
2 .if you have a ZZ4 cam in it.
Without knowing what cam you have now ; impossible to specify springs needed
Old Feb 15, 2011 | 02:09 AM
Curveit's Avatar
Curveit
Like rodj says, you need to find out what Cam you actually have and go from there. As for 1.6 Rockers with the ZZ4 Cam... Kevin McClelland; who helped develop the ZZ4, " The reason I don't like 1.6 Rockers on the ZZ4 Camshaft profile is because when GM designed that Camshaft, the acceleration rates and the opening and closing velocities were pushed to the max. With the additional acceleration of the 1.6 Rockers, the valve actions become unstable. The Valve will bounce on the seat on closing at high engine speed. There is also a lot of inherent noise with adding these rockers to the lobe, which was designed for 1.5 ratio Rocker." (Chevy High Performance May 2009)
Aside from that, you want to keep the Cam pretty small if you're running a TPI on the street. It just isn't going to pull much over 5K even ported, because of the Runner length.
To cam shafts
Old Feb 15, 2011 | 07:15 AM
Crowhater's Avatar
Crowhater
Thanks guys I guess I will look at that gear change then.
Old Feb 15, 2011 | 07:51 AM
rodj's Avatar
rodj
Might want to reconsider that ;
3.07 is recommended best all round ratio for a TPI car.TPI cars have gone slower with lower gears because engine passes through the torque range too fast
Comments from someone who actually knows what he is talking about
http://forums.corvetteforum.com/1568185079-post21.html
As Curveit notes above
" It just isn't going to pull much over 5K even ported, because of the Runner length."
Do the rpm vs mph maths and see what the optional gear sets give you
Old Feb 15, 2011 | 08:03 AM
Crowhater's Avatar
Crowhater
So what do I do guys?
