How do you pull codes?
Old Apr 12, 2002 | 10:43 AM
LayZ's Avatar
LayZ
Default How do you pull codes?
On a 86 vette, do i need a code scanner? or can i jump pins with a paper clip?
Old Apr 12, 2002 | 10:58 AM
Rob90's Avatar
Rob90
Default Re: How do you pull codes? (LayZ)
Here is a link that will help
http://www.hotrodder.com/nick/ecm%20codes.htm :D
Old Apr 12, 2002 | 07:43 PM
LayZ's Avatar
LayZ
Default Re: How do you pull codes? (Rob90)
Ok i'm fine up until code 12. which is flash pause flash flash pause flash flash but what about after that? what flash sequence is 36? 44?
Old Apr 12, 2002 | 07:58 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
Why, do you want a 36 and 44? :D
ECM will flash 12 three times, then codes, then 12 three times again. If no codes, it will just flash 12 6 times.
36 would be: flash, flash, flash; flash flash flash flash flash. (3 times)
12 would be flash; flash flash. (three times)
Can you guess what 44 would be?
Old Apr 12, 2002 | 09:16 PM
Bender's Avatar
Bender
Default Re: How do you pull codes? (PeteL)
I think you missed a flash. :D
Old Apr 12, 2002 | 09:34 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
LayZ, after the first three "12"s, it flashes in succession each trouble code three times and then concludes with three "12"s.
Old Apr 13, 2002 | 04:40 PM
LayZ's Avatar
LayZ
Default Re: How do you pull codes? (65Z01)
Ah ha! ok i'm a bit retarded but i saw the pattern. I am going to check the codes, thanks for all your help. :D
To How do you pull codes?
