Getting everything together to drop the 383 in this weekend. Received my new Throttle Body (52mm Professional Products) and it is apparently for an LT1. The TPI lower housing fits on fine and it comes with both linkages but.... The TPS is of the LT1 configuration.
My question is: can I just upgrade to LT1 TPS and wiring pigtail? I think it should be pretty straight forward but just wanted to know if anyone has done this or has any reason why it shouldn't work.
Correct, but the OP has an 86 with a 165 ECM and no programming to calibrate TPS idle voltage.
How does he set his TPS idle voltage without the ability to adjust ?
I would have to think that slotting the LT1 TPS, is going to be required.
I made my 91 adjustable. Set it to .54@ by slotting the tps after adjusting you're throttle body
