TPS Install
Old Feb 19, 2011 | 02:34 PM
93stroked's Avatar
93stroked
Default TPS Install
Hello, is there any calibration that needs to be done on a new TPS for a 93? Thanks Mike
Old Feb 19, 2011 | 04:15 PM
sailorsteve's Avatar
sailorsteve
FSM says there is a relearn procedure that calls for a Tech I (or Tech II) scanner. Probably some aftermarket equipment will work also, try "search".
Old Feb 19, 2011 | 04:35 PM
93stroked's Avatar
93stroked
Very cool,, thank you
Old Feb 19, 2011 | 05:27 PM
C4vettrn's Avatar
C4vettrn
Default Use this!
http://www.golenengineservice.com/do.../Adj%20TPS.pdf
To TPS Install
