Radiator over flow
Old Feb 21, 2011 | 09:28 PM
mattjohn245's Avatar
mattjohn245
Default Radiator over flow
Does anyone know if you can leave the over flow off? Im trying to make my engine bay look nice and the big tank is very bulky. anyone have any suggestions or know anything?
Old Feb 21, 2011 | 09:49 PM
jfb's Avatar
jfb
So you don't care if you overflow antifreeze on the road? Nor are you concerned that the coolant that flows out isn't likely to be replaced!
The overflow container allows the engine to accomodate high momentary temperatures and not lose coolant so it is available for the next heat cycle. Eliminating the overflow container would be a serious loss of a protective device for your engine.
Old Feb 21, 2011 | 09:57 PM
mattjohn245
I am aware of those factors.. and I do have a whole new cooling system. And I have been keeping a bottle of coolent with me. I seen a small billet tube over flow Im considering.
Old Feb 22, 2011 | 01:45 AM
rodj's Avatar
rodj
anyone know anything?
Year model you are talking would be nice.
If you are talking about a late model C4 then the "big tank" is the thing that holds the pressure in the system
Only on early cars is it a catch can
Old Feb 22, 2011 | 01:56 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
So you don't care if you overflow antifreeze on the road? Nor are you concerned that the coolant that flows out isn't likely to be replaced! Eliminating the overflow container would be a serious loss of a protective device for your engine.
I'm not sure of this one owns a Vette. Appears he may just want to dress up and show.
His list of mods include: "air freshener (: and tach"
Old Feb 22, 2011 | 08:43 AM
mattjohn245
It's a 95 LT1 out of a vette, but I bought it swapped into a silverado. The 93 pace truck to be exact. I think it's the original holding take for the over flow from the original engine.
Old Feb 22, 2011 | 09:10 AM
rodj's Avatar
rodj
It's LT1 swapped into a silverado. .
Does your truck radiator have a cap to keep pressure in?
If so you can delete the LT1 header tank and just use a overflow bottle off the radiator
Old Feb 22, 2011 | 10:07 AM
mattjohn245
It does have the pressure cap.
To Radiator over flow
