Hooker header problem 93 corvette
Old Mar 1, 2011 | 02:34 PM
c4-c6 driver's Avatar
c4-c6 driver
Default Hooker header problem 93 corvette
1993 Corvette; 2 years ago I purchased a new set of HOOKER SUPER COMP,2151-1HKR Headers (84-96) corvette 350.I just finished Engine rebuilt,and went to use the headers and found ,that the right hand header, pipe #2 cylinder is laying tight against the top of motor mount; #4 cyl pipe is adout .025 from hitting the rear edge of the engine mount. Has anyone run into this problem with HOOKER HEADERS before; if so what/how did you FIX the problem??? Left Header fits perfect...
Old Mar 1, 2011 | 02:55 PM
oldalaskaman's Avatar
oldalaskaman
those issues are usually fixed with a few light blows with a hammer in the areas that are too close. its an issue with multi year fit headers thats been going on 40 plus years that I know of.
Old Mar 1, 2011 | 03:18 PM
WW7's Avatar
WW7
I have heard of guys having to turn the bolt around on the motor mounts for clearence, but never heard of the header hitting the mount..WW
Old Mar 1, 2011 | 10:07 PM
C409's Avatar
C409
.......... What heads are you using ? ........................
Old Mar 1, 2011 | 10:34 PM
383vett's Avatar
383vett
I've run a couple of sets of 2151s and haven't run into any clearance problems. The headers are tight with straight plug heads, but other than that, everything was fine.
Old Mar 1, 2011 | 11:20 PM
85vet's Avatar
85vet
Cruise-In V Veteran
I had to do this!!!!
Old Mar 2, 2011 | 01:43 PM
c4-c6 driver
gm. Lt-4
Old Mar 2, 2011 | 01:52 PM
c4-c6 driver
Maybe "HOOKER" made a mistake in MFG. the Headers. I was hoping that a few other people had the same problem, before I go to back Hooker to see what they say...
Old Mar 3, 2011 | 11:09 PM
davenbocafl's Avatar
davenbocafl
im running hooker 1 3/4 comp headers on my 86 with afr heads and had no problems
Old Mar 4, 2011 | 12:54 PM
c4-c6 driver
I could be wrong but I think that"GM" changed the engine mounts in 92-96 for the LT-1/LT-4 engine , thats the only thing I can think of that may be causing the problem...
To Hooker header problem 93 corvette
