Headlights/Dashlights 88C4
Old Mar 6, 2011 | 08:47 PM
Ken88c4,08c6's Avatar
Ken88c4,08c6
6th Gear
Default Headlights/Dashlights 88C4
Happened about a week ago,Driving home headlights on everything working great,then the dash lights went out, turned light dimmer switch nothing changed ,a/c (temp/outside display light) stayed on as did the radio display.got home turned lights out dash lights came on,is there a sensor that controls this system?.
Ken
Old Mar 7, 2011 | 07:54 AM
HlhnEast's Avatar
HlhnEast
Check your TAIL fuse
Old Mar 7, 2011 | 09:07 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
There is a photocell that controls brightness. My fuzzy memory recalls a blown low amp fuse may cause problems with the photocell control, just not 100 % sure what fuse it was. It may have been the 3 amp instrument fuse.
Anyway, here is some info on cluster from my FSM >> http://members.shaw.ca/dankai/Instru...%20Cluster.pdf
Here is another link to digi dash repair > http://www.batee.com/corvette/dcrg/index.htm
Old Mar 7, 2011 | 06:28 PM
Ken88c4,08c6
6th Gear
Default Instrument lights
Thanks,that was the problem I hope!!,the 3 amp fuse was blown,why it blew is another question?
Thanks again
Ken
To Headlights/Dashlights 88C4
