Ignition question
Old Mar 9, 2011 | 03:35 PM
Crowhater's Avatar
Crowhater
Default Ignition question
Last weekend after making six 1/8 passes the car died on us. The distributer was hot to the touch, talking real hot. Everything is new, plugs, wires, coil, cap, rotor, modual. After about 1/2 hour the car started up just fine. I have never seen this issue while driving it.
Old Mar 10, 2011 | 02:31 PM
Lemme's Avatar
Lemme
St. Jude Donor '10
If you are saying the car wouldn't crank when hot then starter motor issues when hot are not uncommon. If your saying the engine just cut-out whilst running then that is a different issue.
Have to be more specific.
Old Mar 11, 2011 | 01:12 PM
Crowhater's Avatar
Crowhater
Guys it is ignition not fuel. I had no spark until the distributer cooled down. Everything is new including the modual and I keep a spare in the glove box. Why is the dist getting hot? Do I need to put a vent in my distributer cap?
Old Mar 11, 2011 | 02:22 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
You don't say what year your car is. If its an L98, next time it happens, take the coil cover off and see if the coil is getting hot.
Old Mar 11, 2011 | 02:33 PM
Crowhater's Avatar
Crowhater
The car is a 1990 coupe zz4 crate engine. I did take the cover off and the coil was hot to the touch, I am talking real hot.
Old Mar 11, 2011 | 02:51 PM
engle1147's Avatar
engle1147
Still got the (secondary) ground strap installed for the coil?
Looks like this : http://shop.advanceautoparts.com/web...S_667381327___goes in the the center slot for the connection terminals of the distributor cap. The strap can stay stuck in the cap and can be easy to miss when replacing a cap.
Old Mar 11, 2011 | 02:53 PM
Crowhater's Avatar
Crowhater
Looks like this goes in the the center slot for the connection terminals of the distributor cap: http://shop.advanceautoparts.com/web...S_667381327___
Yes I do, they did not have it on before and the cap melted in the center so when I replaced everything I installed one. I did not however check that middle wire to see if it has a good ground.
Old Mar 11, 2011 | 03:13 PM
engle1147's Avatar
engle1147
Center secondary ground wire should be "black" in color
Old Mar 11, 2011 | 03:22 PM
Crowhater's Avatar
Crowhater
I have got something crazy going on for sure. Sometimes when I launch the car it will go to missing and popping, and this happens if it is cold or hot. We have narrowed it to the wires that plug into the ecm because when we move them around the problem goes away. I made a new 12G ground wire from the battery to the Plentum, it bolts to the throttle cable bracket.
Old Mar 11, 2011 | 06:51 PM
bill mcdonald's Avatar
bill mcdonald
Out of curiosity, did you put grease of some sort on the module base?
I see you think you have a wire at the ecm issue. have you checked to see if the chip is still seated in the ecm?
Old Mar 11, 2011 | 06:55 PM
Crowhater's Avatar
Crowhater
We did have an issue with one of the chips wiggling but we changed to a different chip.
To Ignition question
