bench bleeding a brake master cyinder
Old 03-18-2011, 07:10 PM
oldace84
oldace84's Avatar
St. Jude Donor '04 & '05
Default bench bleeding a brake master cyinder
what are the fitting sizes (2 different) to make up a bench bleeder for my master cylinder? can not find a kit just to do the master cylinder which is new from Wagner...brand spanking new from rock auto. no bleeder in the kit.
thanks for the help?
Old 03-18-2011, 07:44 PM
oldalaskaman
oldalaskaman's Avatar
if you dont mind a little mess , you can cover the holes with your fingers, pump the piston, while the piston is pushed in cover the holes tightly with your fingers, release the piston and repeat probably 4-5 times, use a towel to catch the fluid and a clamp of some sort to hold the M/C. ......no school like old school
Old 03-18-2011, 11:46 PM
Richard Church
Richard Church's Avatar
I have done that way for years. Works fine.
Old 03-19-2011, 02:07 PM
oldace84
oldace84's Avatar
thanks
Old 03-19-2011, 02:10 PM
surfer93
surfer93's Avatar
$1.99 at Advance, get a block off kit for bleeding the M/C and do it with no mess and no worries about air.
To bench bleeding a brake master cyinder
Quick Reply: bench bleeding a brake master cyinder
