Bothersome alert
Old Mar 29, 2011 | 10:15 PM
JerryCVA-61's Avatar
JerryCVA-61
Default Bothersome alert
Is there any easy way to extinguish the Low Tire Pressure Warning System (LTPWS) light short of taking the entire dash panel apart?? I continue to chech the tire pressure, which is a constant 30psi, which is recommended. The brakes are fine, the handling of the 95 coupe is perfect. Everything seems as it should be, however after taking a long trip to Bowling Green this past weekend, the warning light becomes a troubling thing to look at while driving the 1000 mile roundtrip.
Old Mar 30, 2011 | 12:01 AM
Dads90's Avatar
Dads90
Only removing the bulb in the DIC is the easiest way. The system receives lots of false signals and will come on at will. Mine comes on in the same spot every day.
