Superram take 3...Help Needed
Old Apr 3, 2011 | 12:53 PM
Deepa's Avatar
Deepa
Default Superram take 3...Help Needed
OK...
So this superram is kicking my ***. Installed two times so far, and i still have a vac leak. The first install's leak was terrible. This second install is much better, but still leaks on the passenger side runner to intake base seal.
When the runners are installed and torqued to 20-25 ft lbs, there is a .024 " gap on the inside portion of the passenger side runner when a straight edge is ran across the two runners. ( the part where the plenum bolts to). This gap is huge, you are talking about a credit card sliding under the straight edge.
My feeling is that when the plenum is bolted on, it is drawing the runner away from the base, and creating an air leak. (IF the runner is seated correctly to begin with.) Since you cannot get to the inside bolts with the plenum on, its not like you can tighten everything down slowly. THe runners have to go on tight, then the plenum. Unless I am missing something, and please let me know.
On the second install, i used the right stuff for sealer on new gaskets. The drivers side finally sealed up. The passenger side is still sucking air, making for a very irratic idle. All of the bolts were test fit to make sure they would not bottom out. Shortened a few, and got longer ones for some of the others.
I am at the point now where the intake and base are coming off, getting cleaned up, and taken to a machine shop. I am going to assemble everything dry, and have the shop make all of the sealing surfaces on the same plane. I am also going to have them dowel pin the runners to intake base. Part of me wants to buy a miniram. But I have the 219 cam installed and want to see this superram/219 combo. I have so much money and hours invested into this intake set-up I do not want to give up yet. This machine shop is the 3rd strike, and if it fails, its going to the scrap yard. It is getting sickening with the dollar amount and emotional distraught this intake has inflicted on me. Has anyone ever gone this far to make this work? While everything is apart, all bolt holes in the intake base are getting helicoils. I installed half of them already when I found out the bolt holes were stripped (after installing the intake of course), and I am not taking the chance with this anymore.
I am open to any and all suggestions on getting this to stop leaking. I have read about epoxy being used to build up areas, and using the right stuff in two different stages, etc...All of that works but if the plenum is pulling the runner away when tightened down, i am screwed.
I really feel pinning the runners will keep it all aligned, and fly cutting the top plenum seating surface to get rid of that .024" gap will make all of this sit better. I am beginning to wonder if this one of the incorrectly machined units that I have heard about.
Thanks,
Mike
Old Apr 3, 2011 | 01:04 PM
383vett's Avatar
383vett
.024 is a lot. It's possible that your setup was not machined correctly or has warped. I bought my setup new umpteen years ago and at first I tightened the runner to base bolts and the runner to plenum bolts slowly and together so everything would be pulled into alignment, instead of tightening the runner to manifold bolts tight, then the plenum bolts. Now I have both gaskets rtvd on one side and use lithium grease on the other side and haven't had to change gaskets in years even though I remove the setup at least once or twice a year. You can tighten the inner runner to plenum bolts with a 1/4" box end wrench. I have my plenum lid rtvd down and haven't opened it in years. I use a 1/4" drive air ratchet to tighten most of the 16 plenum bolts. I need to use a box wrench on 3 or 4. Good luck. Willie
Old Apr 3, 2011 | 01:34 PM
eguyett1985's Avatar
eguyett1985
When I first got my SR years ago, I found some high spots on the machined surfaces at both the runner/manifold and runner/plenum surfaces with a straightedge; massaged them both carefully and got them nice and true. I install all my SR gaskets dry and I have never had any vacuum leaks. You should be able to completely tighten the runners to the base and then move on to the plenum; I have no problem with that. I agree with the advice above, go back and carefully check for some machining inconsistencies and you will probably find the problem. Good Luck!
Old Apr 3, 2011 | 03:20 PM
Vic'89's Avatar
Vic'89
Originally Posted by Deepa
Part of me wants to buy a miniram. Mike
That a very good idea !
Vic
Old Apr 3, 2011 | 03:32 PM
pologreen1's Avatar
pologreen1
Vic
Old Apr 3, 2011 | 05:19 PM
1989TransAm's Avatar
1989TransAm
One other posibility. Make sure you are using the right bolts for the intake manifold at least the ones in the area of the runners. Some bolt heads can be high and cause the runner not to seat. This is primarily with the later L98s with the new angled manifold bolts.
Old Apr 3, 2011 | 05:29 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
It came like that from the box?
Old Apr 3, 2011 | 06:51 PM
Hooked on Vettes's Avatar
Hooked on Vettes
You do realize the two runners are not the same?
You can tell which runner is for what side by looking at what
I think are the runners egr passages. The egr hole is oblong
shape/ up and down for the passenger side and the driverside
shape is oblong but tilted at an angle.
Old Apr 3, 2011 | 06:58 PM
stevie1dr's Avatar
stevie1dr
I just installed a super ram myself, and ran into the same difficulty. The culprit was the intake bolts just touching the runners, which wouldn't allow them to sit dead straight which in turn through off the plenum enough to cause a vacuum leak. You need to check very carefully to make sure the runners are not in contact with the intake bolts, or anything else.
Once we discovered the problem we trimmed the bolts a bit to allow the runners to seat properly, and no more vacuum leak.
Hang in there with this system. You're going to be very happy with the performance once you get it installed and the kinks worked out. I'm running mine on a 383 with a 58 mm throttle body, a Comps cam, 32 lb injectors and a 255 lph Walbro fuel pump. I switched to a MAP sensor system and got rid of the MAF sensor. Another great thing to do, as you eliminate all the problems associated with the MAF sensor. If you want to switch just contact EFI and they can supply you with everything needed as well as information for your tuner to help in getting it all performing to the max.
After you get it running and the tps set properly, get a good tuner (if you don't do it yourself) and you will be amazed at the power it will produce.
Steve
Old Apr 3, 2011 | 09:01 PM
Calderone's Avatar
Calderone
Deepa, a cup of patience, i think you are on the right track
I've read so many horror stories but it was not so bad, i suspect you
have a warped unit,don't give up yet,give it some more.
Make a list of every detail that might be getting in your way and tick it once discarded.
Im running the 219/SR/AFR195 Combo and i'm very happy with it, and ...im running it at 6°
i haven't dialed in it yet !!!
Im adding Drag Radials next week because street tires are a joke with this ...
So i bet there's more sweetness from this combo !
Old Apr 4, 2011 | 12:02 AM
383vett's Avatar
383vett
Don't give up, SuperRams can flat out haul...
Old Apr 4, 2011 | 09:04 AM
Deepa's Avatar
Deepa
The intake bolts are not in the way, i triple checked last night. I am hoping its something stupid like that.
My car is a 91 so it has all of the MAP stuff...no MAF to deal with.
I am using allen bolts and the inner runner bolts have been drilled out and threaded into the runners with loctite and saftey wires.
As far as them being on the correct side, i think they are but i am not sure.
What would this cause if they are not on the correct side? It appears to be leaking where the egr tubes are....
Are both sides on the intake base where the runners bolt up to the same on both sides? Or are they on slightly different angles for whatever reason? The .024" is a ton and I am wondering if it is even fixable. I feel there is an issue where the runners meet the base and that is causing the plenum surface to be out of true by so far.
ANy other ideas welcome.
I am not giving up on this yet. I really do not want to pull the intake base though. I am trying to avoid it at all costs but I may end up having to pull it.
Thanks,
Mike
Old Apr 4, 2011 | 09:11 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I had a bow across the top of runners, but I had already planned to stud the interior bolt locations, which allowed me to torque the hell out of the inner portion and pull it all flat.
You may want to try the same or similar. Also, if you haven't already put a slot on the tips of the runner to plenum screws, do so. It will allow you to use a small flat blade from the inside of plenum, to pull up all the screws and then tighten with wrench.
Here's a few pics I added info to, for another member.
Old Apr 4, 2011 | 09:15 AM
AGENT 86's Avatar
AGENT 86
Lol, I should have read your last post.
Old Apr 4, 2011 | 09:16 AM
AGENT 86's Avatar
AGENT 86
Lol again, it wasn't there when I started.
Old Apr 4, 2011 | 09:17 AM
Calderone's Avatar
Calderone
They might have a slightly different angle, you have to be 100% sure they are on the right side,compare the base to runner holes on each side, one hole is diagonal the other is straight.
Old Apr 4, 2011 | 09:22 AM
AGENT 86's Avatar
AGENT 86
Mike
What I have read and found to be true on my SR, is the gasket fit to egr port may not me correct. If I had used the gasket the way it was intended, I would have had a leak there. Since I have no EGR, I sealed that with some more Right Stuff.
Check your gasket fit to EGR runner port.
To Superram take 3...Help Needed
Old Apr 4, 2011 | 10:06 AM
cumbercr's Avatar
cumbercr
The runners do have a left and right side. If you mix them up there will be a vacuum leak. On one side the EGR slot is vertical and on the other side the slot is at an angle.
When I install mine I first apply RTV to the manifold side of the runner gasket and then temporarily install the runner. I leave it set for 24 hours to cure the RTV. Then I remove the runner, apply RTV to the runner side of the gasket and permanently install the runner. I torque the bolts to 25 lbs.
I enlarged all the bolt holes on the top of the runners by 1/32 to allow a little play when trying to start all the bolts. I also installed studs for the inner middle bolts and I slotted all the runner to plenum bolts on the end to speed up installation. I use white lithium grease for the runner to plenum gaskets.
Old Apr 4, 2011 | 11:38 AM
Deepa's Avatar
Deepa
Stupid question but how exactly do i figure out which is which? Is it self explanitory when i have it all apart??
I want to try the 2 part install of the runners one time before i pull the intake and bring it all to the machine shop
Thanks.
Mike
Old Apr 4, 2011 | 11:41 AM
Calderone's Avatar
Calderone
of course check your gaskets ...they are not the same
same as the runners, one is for left one is for the right side
one is angled the other is straight
