87 Fuel pump problem
Old Apr 3, 2011 | 03:04 PM
vetteset8087's Avatar
vetteset8087
Default 87 Fuel pump problem
My 87 is having fuel pump problems. The fuel pressure just drops off while the car is running. I replaced the fuel pump relay but it still did the same thing. I replaced the fuel pump yesterday thinking it was the problem but it wasn't. When I jump the connecter at the oil pressure switch sometimes I get fuel pressure but sometime I don't. If I tap the jumper on and off quickly I can get the fuel pump to run again sometimes.... while I'm doing this I can hear the relay behind the battery near the driver's side door ( burn off relay ?) clicking. anybody have any ideas ?
Old Apr 3, 2011 | 03:33 PM
vetteset8087
When I turn the key on I don't get the couple seconds of fuel pump like I should either. But again tapping the jumper quickly on the oil pressure switch gives me fuel pressure after a while.
Old Apr 3, 2011 | 04:17 PM
billybonesvette's Avatar
billybonesvette
4th Gear
Bad oil press switch?
Old Apr 3, 2011 | 05:52 PM
vetteset8087
The connector is unplugged from the oil pressure switch while I'm using the jumper. So the oil pressure switch is out of the loop.
Old Apr 4, 2011 | 03:03 AM
OkieC4's Avatar
OkieC4
Have you checked the ground for the fuel/pump/tank unit?
Old Apr 4, 2011 | 10:03 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Does the pump run if you apply 12v to terminal "G" on the ALDL connector ?
http://members.shaw.ca/corvette86/Fu...mDiagnosis.pdf
Old Apr 4, 2011 | 02:39 PM
vetteset8087
Where is the ground to the tank located ?
Old Apr 4, 2011 | 03:01 PM
OkieC4's Avatar
OkieC4
G101-Near RH Side Of Battery, On Frame
G104-Rear Of Engine, Below LH Valve Cover
G115-On Frame, Behind LH Park/Turn Lamp
G116-On Frame, Behind LH Park/Turn Lamp
G117-LH Side Of Engine Compartment, On Front Crossmember
G125-Behind RH Kick Panel
G201-Behind I/P, Near LH Side Of Steering Column
G320-On LH "B" Pillar
G400-On Frame, Above LH Rear Wheel
G401-Base Of RH "B" Pillar
I would think the pump ground is either on G400 or G401 on a 87, probably G401 but I'm not 100% sure which one.
Old Apr 4, 2011 | 08:54 PM
rodj's Avatar
rodj
Does the pump run full time if you jumper the OP switch
To 87 Fuel pump problem
