problems..
Old Apr 6, 2011 | 08:16 PM
connorp's Avatar
connorp
Default problems..
my 1992 lt1 won't get out of park. it will start, but when i try to go into drive it wont go anywhere. any ideas on what it is?
Old Apr 6, 2011 | 08:32 PM
Lemme's Avatar
Lemme
St. Jude Donor '10
Generally you can't shift to D from P unless your foot is on the brake. So is the interlock switch playing up?
Old Apr 7, 2011 | 11:08 AM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Are you saying the shifter won't go into drive or the car won't move once its in drive?
Old Apr 7, 2011 | 01:43 PM
marcg202's Avatar
marcg202
Not to sound like I'm some sort of super mechanic but check the Brake lights to make sure they are not burned out or not coming on. I know on my 4runner and my father's ford they do they exact same thing. It's is a safety control issue on most vehicles. Basically no brake lights equal no driving. I hope this is your problem because talk about your easy fixes.
Good luck
Old Apr 7, 2011 | 03:09 PM
OkieC4's Avatar
OkieC4
You have a steering column park/lock control cable which goes from the mid steering column bracket to the shifter assembly. Sounds like it came uncoupled at the backdrive pin at the column or at the shifter linkage. It has an adjustment similiar to a TV cable located at the shifter end. The console needs to come out to check the shifter linkages.
While you are in the shifter linkage, check the neutral/park start switch has not bound up in it's carrier.
Otherwise, disconnect the shift cable at the transmission lever and see if the shifter moves. If it does, then the problem at/in the tranny
Old Apr 7, 2011 | 04:22 PM
pcolt94's Avatar
pcolt94
There is a solenoid that is not working that is probably your problem. It should release when you step on the brake but they get sticky. It's located is the center under the shifter. You got to remove all the plastic and the shift **** to be able to see and work down in there.
The solenoid is usually removed since there is no replacement for it.
(Same answer as I posted in C4 General)
http://forums.corvetteforum.com/c4-g...-problems.html
Old Apr 7, 2011 | 04:25 PM
383vett's Avatar
383vett
Good luck
In the case of Corvettes, brake lights won't affect the tranny linkage. It is a good idea though, unless you're out in the boondocks at 3:00 in the morning and can't move the car because you've got a burned out bulb. I think a number of cars will show a warning on the driver's information center showing what bulb is blown, but I haven't heard of not being able to drive a car due to a bad bulb.
Old Apr 7, 2011 | 05:10 PM
anciano's Avatar
anciano
Removed mine and the problem was gone instantly.
Old Apr 8, 2011 | 12:31 AM
connorp's Avatar
connorp
@paul the car wont shift into drive its stuck in park
Old Apr 8, 2011 | 11:48 AM
OkieC4's Avatar
OkieC4
http://forums.corvetteforum.com/c4-t...-btsi-fix.html
This thread from 2009 may help with your repairs if you have the soleniod installed, but the thread states 95/96... I,m not sure when the btsi was added.
On my 91, I cannot push the button on the shifter down until I turn the key out of lock. I do not have to touch the brake. It is a cable driven lockout as I stated before.
To problems..
