Coolant going into Oilpan
.030 is not very much material so it may need to go out .060 or need to be sleeved to clean it up. Since that piece of whatever bounced around in there so much there is even a strong possibility of a bent rod. I don't mean to be giving bad news but with the type damage you have you have to be sure of everything. Good luck
The piece that caused the carnage appears to have been circular at one point that had collapsed and made of a softer type metal. I can't think of anything that I took off that would look like that.
Does anyone have one '91 stock head and one piston for sale?
Yep..
several possibilities. I'll start with the closest first.
PM me when you;re ready and know what you need for sure. heads, blocks, misc rods w/ pistons etc.
Sorry to see this. Lets focus n getting it fixed.
These guys where right.
Hard to tell what that thing is. The piece off the head seems to fit the entire area that broke off at the water jacket making the other piece seem foreign. Looking at the witness marks on the piston and head it looks like it was bouncing around in the beefy quench area at first then got wedged over near the thin coolant passage where it was able to break. Looks like evidence that a foreign object was dropped inside the engine while you had the intake manifold off that nobody noticed. A coin from a shirt pocket possibly? Because you heard a clunk on startup after the intake gasket swap and the car was fine (besides the intake leak according to you) before the work, the most likely explanation was that a foreign object was introduced during the intake gasket replacement. I mean unless you didn't drain the coolant before lifting the intake off the block I can't see how the cylinders would have been flooded with coolant before cranking either.
I once dropped a small metal object down a cylinder by accident. I had to pull the head off to retrieve it all at my expense. It was a hard learned lesson I never forgot. I didn't actually start the car and cause damage since I knew right away when something went down the engine. I tried everything to retreive it though the spark plug hole and nothing worked. One of the stupidest things I ever did. Ever since I always lay clean paper towels or stuff them inside open intake ports when doing this type of work to prevent anything from falling into the engine. This is the type of stuff I cringe could happen if I don't cover the open ports with clean shop towels and accidentally drop a nut or something without noticing and then start the car. I could not imagine having to explain that to one of my customers.
Get on ebay and find another engine near your home.
Or build a stroker sbc from 401 ci to 500ci with a tall deck and raised cam tunnel aftermarket "LITTLE M" or BRODIX Block.
Don't spend 1 dime on what you have in the photos for an engine that grenaded badly.
BR
I put some more pictures of what was in the cylinder. Like I said it appear to be somesort of soft metal. The item orginally was round and had the colaped into this shape.
I would say it's a nut. You can make out what appear to be ridge lines, what appears to be the flat sides, and you can see metal folded over at the top, which would be the flange or intergral washer at the bottom of a typical nut...
I recall on my L98 car a lot of items being located on studs and then secured with a nut.
Doesn't matter at this point. Time to yank that engine.
Those seem to be the favorite sizes of GM engineers
Kidding aside, there's no doubt the cylinder is fubar'ed. Probably some pretty deep scarring in the walls. My recommendation...
- Determine when you need the car back on the road
- Determine how you will use it...continue as a nice cruiser or ?
- Determine your budget. If you've never built an engine before, you will be amazed at how quickly it can add up
- Determine what you can do vs what needs to be sourced to a shop
Without the above items defined, the range of possibilities will run from dropping a good used engine in there that may need nothing more than a little exterior clean-up to look nice to a full-blown stroker. The associated budget will run from ~$2,000 complete (if you do the R&R yourself) to "the sky is the limit".
BUT, like 96GS said, it don't matter one bit what it was, it killed your engine. All the advice that he gave on planning your next move is good advice. Let us know where you are going from here.
http://santamaria.craigslist.org/pts/2293860436.html
Doesn't look like a woodruff key to me,and if it was a nut that big you would see the oil pan through the piston.pull the engine and let a good profesional machinist look at it and have it fixed right.
Good chance the same crankshaft throw the connecting rod is attached to is bent also.
The cylinder wall might have a crack too.
Magnaflux crack detection time and careful inspection of the crank on machinist "V" blocks and a dial indicator is required if you want to try and save that engine.
If the crankshaft is bent & / or cracked..............
It is just a L98.
How much $$ do you want to spend fixing it?
Take the money and build a stroker engine.
383 's are affordable to build these days.
Brian
if anywhere near Ventura/Oxnard....go to Fains machine shop for the motor repair. Might even make you a piston... and he'll balance the finished assembly.
Good guys. Real machine motor shop.
My motor is running strong11 yrs later...
20th st auto in Phx will have some donor blocks, as will J&D there is Bellflower.Good Luck bud !
