Harmonic Balancer
Old Apr 17, 2011 | 02:42 PM
mediapirate's Avatar
mediapirate
Default Harmonic Balancer
I'm trying to replace the OptiSpark but I'm having an impossible time trying to get the harmonic balancer off. I have an impact wrench but it's to large to get between the balancer and the fans. I tried using a breaker bar but the balancer keeps moving. I don't want to wedge anything in there to stop the engine from turning over my luck something else would break.
Anyone near Norther VA want to help a bother out? :-) I've got beer or cash :-)
Old Apr 17, 2011 | 03:30 PM
STL94LT1's Avatar
STL94LT1
Are you trying to remove the three balancer bolts, or the hub's bolt?
Remove the three balancer bolts, soak it with PB Blaster, then get under the car and knock/beat it forward with a 2x2 and a BFH. Rotate the crank after a couple of whacks, and be careful not to hit on the outside ring of the balancer.
93Rubie's Avatar
93Rubie
You know the holes in the balancer for weights? Shove a punch in there and jam it against the front cross member in front of the balancer. Then when you turn the bolts to loosen, the engine does not turn.
Old Apr 17, 2011 | 03:34 PM
mediapirate
Thanks guys, I've got the balancer to stop moving but I cannot break the 3 bolts free. I've juiced them up with a softner twice so far. I don't have enough space to fit the breaker bar or the impact wrench from underneath. I have an electric impactor so it's large I guess my only option is to buy a AIR system with a smaller impactor to get these things out.
Old Apr 17, 2011 | 04:03 PM
floridamale's Avatar
floridamale
Try a 1/2 inch breaker bar with a pipe extention
Old Apr 18, 2011 | 12:30 AM
383vett's Avatar
383vett
Have a friend crawl underneath hold the flywheel/flexplate with a flywheel turning tool.
Old Apr 18, 2011 | 07:16 AM
mediapirate
Thanks for the help guys, I've been able to prevent the wheel from spinning at this point by wedging a wide mouth pry bar into the tensioner. The head of this one is rubber coated so I don't think it will do any damage to the belt or tensioner wheel. I'm going to torch the 3 bolts tonight to see if that will help break them loose. I was under the impression that the balancer had to come off to remove the optispark but now I understand that only the crank pulley needs to be removed.
On a side note, since I'm pulling everything off the front I'm thinking about replacing the timing chain with a double roller (LT4). I have to buy a replacement timing cover with the water pump gear sealed (CSR electric pump install) so why not?
Old Apr 18, 2011 | 09:44 AM
STL94LT1's Avatar
STL94LT1
FYI: The LT4 timing set is not a double roller. What year is your car?
Old Apr 18, 2011 | 09:48 AM
mediapirate
Its a 95 I'm thinking to make things easier I'm going to pull the radiator and shroud so I have more room. Its never been cleaned before and after 140k I'm sure its ready. That will give me the space I need to pull the balancer and pulley.
Old Apr 18, 2011 | 10:18 AM
383vett's Avatar
383vett
Be a little careful with the torch. The balancer is a 2 piece unit. The outer ring is pressed onto a hub with a rubber seal between them. Too much heat to the balancer can melt the rubber and...
Old Apr 18, 2011 | 08:59 PM
pcolt94's Avatar
pcolt94
I'm assuming you have an automatic as I do and you can't loosen the 3 bolts without the crank turning. You can get a air impact wrench in there to loosen the bolts. You need an assortment of short and long sockets as well as a few short different size extensions and perhaps a universal. It took me a while to come up with the right combination for length to get the tool up in there but it can be done. I'll admit it was a pain and have not done it in a while.
You don’t pull the hub (single bolt) to get the opti off. Only the balancer has to be removed. Also it has to back go on in the position it came off so make a mark (paint) on hub and balancer. I also believe the hub if removed has to go on in the same position also and I don’t think it has a key (need a puller).
Also pay attention to all the other posts above mine or you might make things worse.
Old Apr 18, 2011 | 09:22 PM
mediapirate
I've been able to remove the balancer actually it pretty much fell loose when I freed the last bolt. I didn't mark the position though, I need to replace the balancer it was in pretty bad shape. Is this going to be a problem when I receive the new balancer? I can see the marking on the hub is currently at 12oc. I didn't know I had to mark the posisition of the old balancer when removing when I get the replacement what will I need to do to get it lined up correctly again?
Thanks again!
Old Apr 19, 2011 | 09:46 AM
STL94LT1's Avatar
STL94LT1
The balancer will only go back on one way, the holes are slightly offset.
Old Apr 19, 2011 | 11:06 AM
floridamale
There is a key way in the crank shaft only 1 way back on
Old Apr 19, 2011 | 11:18 AM
STL94LT1's Avatar
STL94LT1
The LT1's hub is not keyed, it can go back in any position.
Old Apr 20, 2011 | 01:47 AM
93stroked's Avatar
93stroked
After the fact: http://www.thetoolwarehouse.net/p-3059-lisle-28500.aspx
Old Apr 20, 2011 | 09:19 AM
floridamale
Cool
I thought it was keyed, Sorry about that
To Harmonic Balancer
Old Apr 20, 2011 | 06:57 PM
SouthernSon's Avatar
SouthernSon
If you take off the hub, you might go to the local bolt store and get a couple of grade 8 bolts in a couple of slightly different lengths longer to start into the threads to pull the hub back onto the shaft. I did and had no problems. As far as timing chain, consider the LT4 extreme chain. After almost 70K miles on my extreme chain, I checked it and found only 1/8" play on loose side. I decided to go for another 70K miles on it.
Oh yeah, in order to seal the oil pan and chain cover, go to the GM dealer and get the good stuff (grey color, in a quarter sized caulk gun cartridge - used in diesels, too). If you have any questions on procedure, PM me. I just did this a couple of months ago and have no leaks.
Old Apr 21, 2011 | 03:54 AM
randyshear1980's Avatar
randyshear1980
3rd Gear
I have a leaking front seal myself.. I took her to two shops, and both called me and said they could not do the job. Looks like I'm in the same boat as you here.. Wish me luck, this is my 1st corvette, and only had her a week or so.
Old Apr 21, 2011 | 07:09 AM
mediapirate
Good Luck! Seriously it's not that bad though I think its just first time jitters or at least it was for me. I realized after I removed mine that it wasn't a a big deal. I would suggest if you haven't started yet, blast the 3 bolts on the balancer down with penetrating oil the day before and 30 minutes before you're ready to remove it. I also tried to tighten them with one good pull, they were no effort removing after that.
On a side note, I took pictures of every part before I removed it. I'm the kind of guy who after working on something always has extra parts? This seems to help with that problem :-)
MP
