Lower temp T-stat recommendations please
Sliding the radiator into place and hooking up the hoses takes about 5 minutes. Removing and replacing the shroud is the time-consuming part, regardless of what kind of radiator you are installing.
They are only accessible (and then barely) if you remove the air canister on the left side and the overflow coolant tank on the right side. Anyone who has done this knows how difficult they are to access.
Or maybe we are talking about different cars. Mine is a '94.
Also - on high mileage factory radiators, they can look clean as a whistle but hidden in-between the cooling fins will be pounds of little gravel, sand, leaves and crap that you can not see, nor will it blow out with pressure. It just reduces the overall efficiency of that factory radiator. I have cleaned a radiator for over an hour using high pressure water and an air hose until I was blue in the face, however when done I could still smack it on the floor of the garage and have sand and crap come out from between the fins. That's why I ordered a new one. DeWitts is great option but a new factory one will work just fine too.
You can replace it with a factory radiator and it will solve some of the issue, but the only way to bring the temperatures down to level your psyche wants to see is through reprogramming your fans to operate earlier in the heat cycle. REPEAT - Thermostat will do NOTHING to temps after normal operating temperature is reached. Once the thermostat opens it is open. So what if it opens earlier or later in the heat cycle. Normal Operating temp are dependent on ambient air temp, cooling system efficiency, and how much air is moved over the radiator. Bigger radiator, and more air via computer tuning of the fans will cool this car to where you are comfortable.
....WW
mine replaced a couple of months ago and it took about 4+ hrs. As I
watched this being done, it appeared the mechanic had to remove a lot of stuff just to get the shroud off to get to the radiator!
Also, what is the easiest way to get all the debris from between the
condenser and the rad? Thanks
IIRC getting the radiator out, cleaning it, replacing the radiator, spark plugs, wires, dist cap, rotor and coil took less than a day in an 88 auto I had many years ago. Most of the time was getting what seemed like 500lbs of crap from between the fins in the radiator, then straightening fins before putting it in.
Some, like me, will putter around the garage and take days to do one little task. I like to remove the old parts, clean them nicely if being re-installed, then consider different replacements, then clean them again, then look at the FSM to see how they look there, make a mental plan of how I'll make my next move, then go watch a few hours of speed channel, then come get on the internet and check out my favorite Corvette websites, then go back down to the garage and look around and decide that I'll finish up tomorrow instead.
I drive and race my car above 60 mph on the freeway. Usually it's between 80-180 mph. I do not have reprogrammed fans. I think everyone who reprograms fans has knowledge issues unless they are racing below 40 mph and need the motor cooler at those speeds. AIR SPEED OVER 40MPH IS GREATER THAN FANS AT MAX SPEED.
Guess what that means? At higher speeds the airflow can EASILY MAINTAIN COOLER THAN STOCK TEMPERATURES WITH A 160 stat. Works for me at highway speeds my car ran cooler and that's where it matters.
I was never concerned with temps too cool because rpms were always over 4500 usually cruising at 6500 so oil temps were always nice and hot.
HorseApples...
First off, if I was planning on building an engine and asked for suggestions, I probably wouldn't see the value of a radiator at his point either.
BUT! After spending countless hours, days, weeks & months of fighting the heat battle....
I know NOW that the radiator is the first mod along with a cat back!
That being said, you can take all the switches, stats and fans in the world and put them up against a new radiator from DeWitts or Reliable.
Nothing will remove the heat from a C4 engine better than a performance purpose radiator.
Remember that heat is your engines enemy.
I should get paid for this.
I used ALL that junk and none worked under all conditions, situations, ambient temps and driving habits EXCEPT for the new all aluminum radiator that is double row, more capacity, greater efficiency AND more reliable.
Ambient temps matter. Heat exchange differentials matter. Air-flow matters (big mouth air dam did help).
My engine temps are so stable now that I added a trans cooler
(6" X 14") in front of the radiator/condensor and have no ill effects with the cooling. The trans runs much cooler as does the engine at a nice stable 185 with a/c on with ambients of 90*. Sitting still in rush hr the temps may rise to 210 until I start to move over 20 mph again. That beats the s*** out of the 230+ that it wanted to run all the time last year...
Bottom line, its all about heat exchange and your cars ability to do so efficiently at all speeds/conditions. If you can loose heat faster than your engine can generate it, then you can manage it, control it and use it constructively. If not, your engine suffers.
..This is also against forum rules, so you should be hearing from a moderator shortly....WW
Second... you are an idiot.
