Lower temp T-stat recommendations please
Old Apr 23, 2011 | 11:42 PM
  #41
5abivt's Avatar
5abivt
Originally Posted by WW7
Why would you even post something like this? First off C4 fans shut off at highway speeds and only come back on below 45mph so this makes the first part of you post wrong..Secondly, 160 degree stats are not any good in the cooler parts of the country because most of use want out heaters to work in the winter. The 160 degree stats also wont let the car reach a high enough temp to evaporate the condensation from the oil in the colder states.Third, if your car doesn't maintain a high enough temperture you will get excessive wear on your motor..Fourth, don't even get me started on you talking about doing 180 mph on the roads where our wives and kids drive there cars....This is also against forum rules, so you should be hearing from a moderator shortly....WW
Yes I understand the fans shut off. They shut off because at speed the air flowing through the rad is greater than what the fans can push. My point was at higher speeds there is sufficient airflow to keep temps lower than stock with a 160 stat without needing to have your fans reprogrammed.
I do agree about using a lower stat in the winter as it takes longer to warm up. at city speeds the 160 stat wont keep the temps lower (if you dont have fans reprogrammed) so the engine will still get up to temperature and everything can do its job.
180+ was done on an airfield. 207 to be exact. My wife and my little girl is not allowed to drive there. My little one wont be driving for another 15 years but I dont think Ill let her when she's old enough.
My whole point was at higher speeds a lower thermostat DOES work. It's not much but it's noticeable.
Old Apr 23, 2011 | 11:57 PM
  #42
RedLS1GTO's Avatar
RedLS1GTO
Originally Posted by 5abivt
I drive and race my car above 60 mph on the freeway. Usually it's between 80-180 mph.
This statement still makes you an idiot.
207mph at an airfield in a C4 huh? Pics and specs of car?
Old Apr 24, 2011 | 12:01 AM
  #43
5abivt's Avatar
5abivt
Why the name calling? Sometimes people do roll-on races ever seen videos on youtube?
Old Apr 24, 2011 | 01:00 AM
  #44
jfb's Avatar
jfb
Originally Posted by RED UFO
I replaced the Condenser last year. That area should be clean.
Thanls for the suggestion
It matters not that you replaced the condenser last year! C4's suck air from close to the road and all kinds of road debris catches in the radiator fins and reduces the heat transfer ability of your radiator.
Also, thermostats only ensure the lowest temperature your coolant will run at, they will not lower your coolant temp. Above 195, your 195 stat is wide open and so will a lower opening temp thermostat and your coolant temp will be identical to what it is now! Why people think a lower temp thermostat will lower their coolant temp in slow summer traffic tells me that they have no idea of how engine cooling systems work.
GM says to shut the engine off and let it cool down if the coolant temp gets to 260 F and that is because 50% antifreeze at 15 psi boils at 265 F. 260 F is a nothing for automobile engines and will harm nothing. I recommend you clean your radiator fins and leave your 195 stat in place, a 180 stat will do absolutely nothing in slow summer traffic.
Old Apr 24, 2011 | 01:36 AM
  #45
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Its Official now!
JFb is in too!
IBTL......
Old Apr 24, 2011 | 02:27 AM
  #46
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Originally Posted by JrRifleCoach
Its Official now!
JFb is in too!
IBTL......
Not yet, I'm waiting for the response to this.
Old Apr 24, 2011 | 07:35 AM
  #47
WW7's Avatar
WW7
Jfb is right, unless you reprogram your fans to come on at a lower temp it doesn't matter which stat you have in your car, the car will run at the same temp..I have a 180 degree stat in my car, I also have the fans reprogrammed to come on at 200 degrees and go off at 184 degrees , so my car never goes above 200 degrees..This is the only way using a lower stat will make a difference at low speeds.If your not going to lower the temp that your fans come on, you might as well use the stock 195 stat.....WW
Old Apr 24, 2011 | 10:14 AM
  #48
leesvet's Avatar
leesvet
I went to the Texas Mile this past fall...(missed the spring run last month),
anyway, I saw $250,000 cars , Lambos, Porches, Ford GTs. Some heavily modified Turbo AND bottle blown Hyabusas, and lemme tell ya...200 is damn hard to do on the mile track. One of the fastest of the day was a mustang shell with a power-stroke diesel......
All of these cars were street legal and driven to the event. One of the baddest Porches (record holder) came from several states away. Drive down, run, drive home.
Some of the nicest runs were Zo6's...a couple that were worth $200K with carbon fiber bodys, other hi-tech stuff. Even hitting 180 was challenging with these very very high HP super lite-weight cars and bikes.
For someone to just casually throw 180 or 207 MPH out there forces me to throw the flag.
BTW...anyone that breaks 200 gets a nice little plaque and a T shirt. Pics are easy enough to post. Events like this are held all over the country at small private airports that are closed or abandoned.
Old Apr 24, 2011 | 11:06 AM
  #49
anciano's Avatar
anciano
That being said, you can take all the switches, stats and fans in the world and put them up against a new radiator from DeWitts or Reliable.
Nothing will remove the heat from a C4 engine better than a performance purpose radiator.
A properly-functioning OEM radiator is perfectly adequate for cooling this engine when and only when there is airflow through it. Moderate-speed forward motion will do it; so will the cooling fans.
I switch on my fan(s) when stopped and idling and the temp climbs to 210 or so, then watch it drop like a stone all the way down to the 185 thermostat setting. I could see spending for a high-performance radiator if I raced the thing, but a couple of bucks for some Radio Shack toggle switches seems more sensible to me.
But I'm a cheap SOB when it comes to this car.
  #50
5abivt's Avatar
5abivt
Originally Posted by leesvet
Rush hour must be a bitch at 180....
maybe he means KPH..?
Ahh you are right !! It was Km/hr !
I think it has an LT1 in it. the shoppe said it was an aluminum head version they got off ebay. They said 325 hp.
Old Apr 24, 2011 | 02:00 PM
  #51
RedLS1GTO's Avatar
RedLS1GTO
I drive and race my car above 60 mph on the freeway. Usually it's between 80-180 mph. ... 40 mph ... AIR SPEED OVER 40MPH ...
Seriously? That's the excuse you come up with when you get called out by people about a ridiculous claim? I have to admit that is a bit confusing though... if you were really just used the wrong unit of measure, your post above says that you race at ~50mph. Well that really doesn't make a lot of sense now does it?
I was never concerned with temps too cool because rpms were always over 4500 usually cruising at 6500 so oil temps were always nice and hot.
So let me get this straight... first you claim that you went 200+ at an airfield (only to later backpedal to the point that you forgot what unit of measure you were using) and now you are saying that you cruise around at 6,500 rpm in what you think might be an LT1?
Yea, that would certainly make me want to trust your expertise. On that same note, your directional tires are going the wrong way in the picture.
It's pretty simple really. People who race down the highway are idiots. You want to race, go to a track. Just this morning, I saw a kid try to jump a bmx bike off of the roof of his house on youtube... although I'm not sure what morons do in videos on the internet have to do with anything.
Old Apr 24, 2011 | 02:07 PM
  #52
WW7's Avatar
WW7
Ouch RED!!!.....WW
Old Apr 24, 2011 | 06:48 PM
  #53
5abivt's Avatar
5abivt
Nice catch with the tires. Direction means almost nothing when it isn't wet. I think I had 2 plugs in that tire too should have seen the bulge after! I'll stop posting so this doesn't get too far off topic.
Old Apr 25, 2011 | 07:10 PM
  #54
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
First... because of the part in bold, you are an idiot.
Second... you are an idiot.
Old Apr 25, 2011 | 08:10 PM
  #55
84cfi's Avatar
84cfi
Why don't you get a manual fan switch and and if that's not enough put in a 160 stat.
Old Apr 25, 2011 | 08:13 PM
  #56
84cfi's Avatar
84cfi
A C4 doing over 200 mph I would have to see it to believe it. If you are going that fast why would you be on these forums you should be a rock star with that kind of money to blow on a raggedy old C4.
Old Apr 25, 2011 | 11:04 PM
  #57
JrRifleCoach
Ain't been around much have you?
There are a few here that will hold down to 200.
But c'mon! "raggedy old C4"???
You must be referring to your own.
To Lower temp T-stat recommendations please
Old Apr 25, 2011 | 11:14 PM
  #58
cv67's Avatar
cv67
St. Jude Donor '05
These cars just keep getting cheaper and cheaper.
Old Apr 25, 2011 | 11:24 PM
  #59
leesvet's Avatar
leesvet
whats the purpose of thumping boogers on ANY Corvette?
Thats a criminal offense in a Corvette forum..
jeeze....
Old Apr 26, 2011 | 02:12 AM
  #60
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Well, I guess you really nailed the answer for the OP then, didn't you?
When I am stuck in traffic on a hot summer day the engine runs hot. ( both fans are working) I have a 195 T-stat in it now. When is suggested to go with to bring down the temerature under those conditions? May be a 180 or 160?
