Identify unhooked wires...help
Old May 3, 2011 | 07:07 PM
tiger38117's Avatar
tiger38117
Default Identify unhooked wires...help
The pictures below show two unhooked harness plugs I just discovered. They are located just in front of the TPI plenum below the intake hose. I cannot see anything obvious they should be hooked to. Anyone identify these?
Old May 3, 2011 | 08:42 PM
bwiencek's Avatar
bwiencek
The one is for the AIR injection solenoid and the other should be the EGR solenoid - I'm guessing that the AIR injection setup and EGR has been eliminated?
Old May 3, 2011 | 08:55 PM
tiger38117's Avatar
tiger38117
No idea. Learning the L98. How do I know this?
Old May 3, 2011 | 09:32 PM
JackDidley's Avatar
JackDidley
I think you are correct. There is a pretty good view of the water pump in the area where the smog stuff should be.
Old May 3, 2011 | 09:57 PM
bwiencek's Avatar
bwiencek
Take some better pics of by the valvecover/exhaust manifold and under the throttle body and we can probably tell you what's missing...
Look at the exhaust manifolds - are there tubes connecting to the 'top' of the exhaust manifold and running to the AIR pump on the driver's side (next to the alternator). The EGR is underneath the upper plenum and will have a vacuum hose running from it to the solenoid then from the solenoid to the vacuum source.
I'd probably guess that the cats have been gutted too knowing that they probably took off all emissions "stuff" to try and eek a little more performance out of the L98.
Old May 3, 2011 | 10:01 PM
tiger38117's Avatar
tiger38117
The car has headers and no cats so I am sure all that stuff is gone too. I'll take some pics later.
Old May 3, 2011 | 10:05 PM
cgantner5150's Avatar
cgantner5150
Hide them under the AC compressor/bracket - that's where mine are at.
Old May 4, 2011 | 07:54 AM
bwiencek's Avatar
bwiencek
Then I'd almost guarantee that's what they are - they both tapped into the exhaust on the stock manifolds and some headers don't have provisions for getting the EGR up to the intake nor allowing the AIR injection in.
If they did remove the AIR pump and I see you're still running it - you might as well gut it and remove the friction from spinning the rotor inside of it - or get yourself an AIR injection pump eliminator pulley.
Old May 5, 2011 | 09:34 PM
tiger38117's Avatar
tiger38117
Is there any reason I can't just snip these off and throw them out?
Old May 5, 2011 | 09:51 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Don't recall if I saved them or threw them away, but I know I cut them off, taped the ends and stuffed them into the injector loom.
Old May 6, 2011 | 02:41 AM
jdraughn's Avatar
jdraughn
Right side horn and/or outside ambient temperature sensor connectors?
To Identify unhooked wires...help
