second head gasget leaking
Old May 5, 2011 | 09:35 PM
Bensons86's Avatar
Bensons86
Default second head gasget leaking
We finished rebuilding my painful project recently only to find anti-freeze in my oil again. We didn't see anything visually wrong with the head gaskets or the intake gaskets. I have attached pics of the heads, because you can see clearly which two cylinders were leaking. Looking at the gasket around this area, there seems to be nothing wrong with it at all. I put a straight edge on the brand new heads and they look straight. I have not done the same with the block, but figure the odds of that cast iron block being warped are pretty slim. Any thoughts on what could have caused the failure? Any suggestions on things to do when we put it back together again?
Old May 5, 2011 | 09:41 PM
87 vette 81 big girl's Avatar
Did you thoroughly clean the block deck surface till it shines and sparkles?
Clean enough to eat off of ?
Did you purchase new headbolts?
ARP or Fel-Pro?
Did you use a calibrated torque wrench(Snap On is my own personal choice)?
Did you follow the factory recommended torque sequence & specs?
Did you coat the head bolt threads with an approved sealer(RTV silicone no good).
Just a few thoughts of mine right now.
Old May 5, 2011 | 09:58 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
ARP or Fel-Pro?
All good thoughts and SOP as far as I'm concerned but I'd like to add one more, run a thread chaser through the head bolt holes to be sure the bolt is not binding in crud & giving a false torque reading. The new head bolts have been a source of discussion on this forum a lot but the fact is that the originals are torque to yield bolts and have to be torqued differently and are meant for one time usage only. I thought that was bs until I snapped one off on a rebuild so now I NEVER install used bolts IF they are originals. Get the ARP bolts with washers and re-use them all you want. (within reason)
Once you get the block deck CLEAN, lay a straight edge across it & check in a whole bunch of different spots with a very thin feeler gauge.
Old May 5, 2011 | 10:09 PM
jfb's Avatar
jfb
Check the block for flatness and check the heads for flatness too. Next head gaskets should be teflon coated made by Fel-Pro, they last much longer than non coated and they seal much better than non coated.
Old May 5, 2011 | 10:37 PM
leesvet's Avatar
leesvet
D. All of the above.
These are very sensitive to the torque sequence and the head bolts being sealed.
Old May 5, 2011 | 11:32 PM
mtwoolford's Avatar
mtwoolford
on the first aluminum head cast iron block I ever did, before I installed the heads I went on the internet and read all I could about this (new to me ) technology. every single article I read stressed that every possible thing that could be done to allow for relative movement between the aluminum head and cast iron block must be done. At a minimum the block must be smoother than in the old cast iron head, steel shim gasket, cast iron block days (where their was little if any relative movement) and a teflon coated gasket was a necessity.
Old May 6, 2011 | 08:02 AM
oldalaskaman's Avatar
oldalaskaman
chevy alluminum intakes used to be famous for leaking antifreeze into cylinders
Old May 6, 2011 | 08:13 AM
cgantner5150's Avatar
cgantner5150
Make sure you use a good thread sealer. Damn near everyone of my head studs weeped coolant on my rebuild. That was a shocking first oil change. Resealed with Permatex thread sealant with Teflon - good to go.
Old May 6, 2011 | 08:44 AM
oldalaskaman
I vote for this one
Old May 6, 2011 | 09:00 AM
cv67's Avatar
cv67
St. Jude Donor '05
Those look to be aluminum rather than iron. No cracks?
Old May 6, 2011 | 09:26 AM
leesvet's Avatar
leesvet
I heard someone say ..... # 7.. come on down
Been stung twice by good 'ol #7.
Old May 6, 2011 | 09:35 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Can't see a thread sealer problem causing coolant to get into combustion chamber.
I would have a closer look at your intake gaskets and how they match up to head ports.
Old May 6, 2011 | 10:14 AM
mike100's Avatar
mike100
I always use permatex form-a-gasket on headbolt threads-the sticky dark brown goo.
Another thing to consider is if the block has a hairline crack on the cylinder wall. I saw that once or twice- it could happen so get a real bright light and check for that just in case.
ON EDIT- I actually looked at the pics...straight edge the intake manifold. omg that's a lot of water!
Old May 6, 2011 | 12:06 PM
Bensons86's Avatar
Bensons86
We installed the heads on the engine stand and the block looked beautiful. We used new bolts and Im pretty sure that we used a thread sealer. I asked my friend but he hasn't gotten back to me on that one yet. The intake and the heads seem to be straight and we did everything according to the book on sequence and torque specs. I suppose thats part of what makes this so frustrating. Thanks for all of the pointers though. I guess I just hate to put it all back together basically the same way and get the same results. I believe the gaskets you see were felpro, but Im not sure on the teflon coating. Im guessing not. If the heads and intake look good on the straight edge they wouldn't be warped enough to leak with a gasket would they? I wouldn't think so.
Old May 6, 2011 | 12:10 PM
cv67's Avatar
cv67
St. Jude Donor '05
Shouldnt be, only takes a minor flub so one leaks it can happen.
Old May 6, 2011 | 01:00 PM
desertmike1's Avatar
desertmike1
This is what the Felpro teflon coated gaskets look like..
This is what the deck should look like when you get it cleaned
you need to use a high Quality 18-20in machinest ruler on edge, and Length wise, with a feeler gauge in order to check the deck for flatness.
Old May 6, 2011 | 01:11 PM
oldalaskaman
an old school trick for chevy's intake manifolds that wont seal, use two gaskets on each side, extra sealer on each end, next was a different intake, and the last best was to hunt down a cast iron manifold, kinda out of the question these days, interesting some of the things you do .
To second head gasget leaking
Old May 6, 2011 | 01:15 PM
Calderone's Avatar
Calderone
is there a way to pressure test the heads ?
might be a cracked head there but all of the above is very important as well
Old May 6, 2011 | 10:42 PM
Midnight 85
Depending on which head was on the bad side it is either 5&7 or 4&6 getting water. I think you can rule out a crack, that would just be one cylinder most likely. It still looks to me like false torque readings in those bolt holes, there's a lot of crap that builds up in the bottoms and your new bolts may be just a tad longer than the originals. Did the bolts come with washers? Are you using the washers? If not you definitely should, especially on aluminum heads. Also the lack of washers would extend the bolt further down into the hole compounding the false torque reading possibility.
Old May 6, 2011 | 11:44 PM
l98tpi's Avatar
l98tpi
Max G’s
Since you have it apart again, before putting it back together, take both heads to a machine shop and have them checked for cracks and warpage. It's not bad money just to make sure. Also, don't want to seem too critical, but those head gaskets look like the cheap Fel Pros that AutoZone and other chain stores sell. Get the OEM head gasket sets from the dealer or GM Performance Parts. When I rebuilt mine over the winter, I was advised by a reputable builder to use the OEM gaskets.
