Targa top removal help
Old Apr 19, 2002 | 10:38 PM
poppy's Avatar
poppy
Cruise-In III Veteran
Default Targa top removal help
I checked the archives and could not find info on this . I tried to remove the top for the first time. I had no trouble with the back bolts using a T-40 torx socket but when I tried the front I could not get the short socket in the deep holes in the plastic trim. Question - Are these bolts also T-40? If so, I can proceed to getting the proper tool whatever it may be. Thanks, Mike
Old Apr 19, 2002 | 10:39 PM
SlowJoe's Avatar
SlowJoe
Default Re: Targa top removal help (poppy)
Same size head as the ones in the rear.
Old Apr 19, 2002 | 11:29 PM
VetteNoob's Avatar
VetteNoob
Are you using the factory top removal tool? That bolt in pretty far in there and you will need a torx with a long thin shank to get to it.
Old Apr 20, 2002 | 12:20 AM
tarheelracer's Avatar
tarheelracer
Default Re: Targa top removal help (VetteNoob)
Here is a link to where you can get the tool. It just has an extra long shaft. http://www.ecklers.com/product.asp?p...dept%5Fid=1100
Old Apr 20, 2002 | 01:34 AM
okinawa86vette's Avatar
okinawa86vette
Default Re: Targa top removal help (tarheelracer)
You may also be able to pick up a Torx #40 screwdriver at a hardware store. That's what I ended up doing.
Old Apr 20, 2002 | 03:12 AM
poppy's Avatar
poppy
Default Re: Targa top removal help (okinawa86vette)
Thanks for all your help. :)
To Targa top removal help
