Door Ajar light flickers
Old May 13, 2011 | 09:47 PM
robsball's Avatar
robsball
Default Door Ajar light flickers
The door ajar light flickers from time to time, especially when the road is bumpy. Sometimes is stays on, and then sometimes it doesn't come on at all. Suggestions?
Robin
Hey MODS, please delete this thread. I missed the thread under general discussion and saw it only after I had posted this one. I have my answer. Thank You - Robin
Last edited by robsball; May 13, 2011 at 10:10 PM. Reason: found answer in general discussion
Old May 15, 2011 | 09:53 AM
Red Dwarf's Avatar
Red Dwarf
I would try shooting some WD-40 on the switche(s) & exercise them. If that doesn't help it's time to change them out.
Old May 16, 2011 | 11:52 AM
pcolt94's Avatar
pcolt94
Also pull out the self adjustment tab on the switch. You may just need to take up the slop.
Old May 20, 2011 | 06:43 PM
92nsx's Avatar
92nsx
^^^ ? self adjusting ****? I looked at mine and didn't see anything. Mine was doing the same thing, after messing with it for a hour i sad F it, and taped a washer with electrical tape where the **** make contact with the body. Wouldnt mind finding the real fix. Maybe we just need to replace the switch?
Old May 21, 2011 | 09:09 AM
Steve59's Avatar
Steve59
On the head of the "door agar" switch that's located on the door there is what appears to be a "button". Put your finger nail under that button and pull it out about 1/4 inch. Close the door, the button will set itself to the proper length.
Old May 21, 2011 | 03:13 PM
jeffp1167's Avatar
jeffp1167
Originally had self adjusting thing sticking out. most break off .... replace switch is best idea
Old May 21, 2011 | 03:54 PM
samsonb's Avatar
samsonb
On mine, I pulled out the self adjuster and slid on a couple of #60 o-rings. That fixed the ajar light flashing on/off.
To Door Ajar light flickers
