ICM Test
1992 LT1 auto.
Secondary resistance on the coil is about 10,000 ohms. I realize thats out of range but is it too high, should I go ahead and replace the coil? Manual says the range should be 5,000 to 7,000 ohms.
Some of the auto parts places can check it, but they can't check it for working while hot.
Check for spark at the coil
Check for spark at the plugs
I just found out the opti rotor can dramatically fail without setting a code as well.
I'd change the coil at least. Do some checks:
If yours won't start at all, as stated above many parts stores can test the ICM. If you have a intermitant hot problem the ICM may test good but still cause a problem. Since you didn't say I'll assume you don't have a SES light.
I would start out checking the drive from the ECM and check for the 1.0 - 4.0 volts AC in pin "B" of the ICM connector. If that is good then you can proceed with checking the ICM and coil.
I have never had a ICM checked at a parts store. If they truly load the ICM then it should get hot. If it stays cool and checks good, you could be getting a false positive check.
I have always felt that substitution is the best test and check but that does not help your present problem. If they say it should get hot when it is tested, then that might be an indication it is defective
Hope this helps.
I have never looked in the FSM for this information. I don’t know where you got your numbers from, the FSM or another info book. I don’t know and have not researched if 10K is objectionable or not.
The troubleshooting flowcharts are great.
The Haynes is not so good.
In reviewing the FSM for resistance measurements for the coil, I could not find it anywhere. They don’t seem to be concerned with furnishing that information, they may not feel that it is a valid piece of information. Aside from an open primary or secondary winding, an ohm meter is not a reliable way to check if a coil if is actually defective. You really need to check for shorted turns and the "Q" of the windings.
Aside from all that technical information, the ICMs break down much more than the coils do. The ICM is quick to replace although costs more than the coil. The coil is a bigger job to replace as you have to mount it in a bracket and possibly cut off some rivets.
I would start off checking all connections and plugs. You have two unknowns in there now, coil and ICM. You can actually reconnect the original coil back in there by just connecting it and hanging it.
I would re-check any items you have already just to make sure of the status especially the injector pulses. Recheck the opti connections also.
Swapping the original ICM back in is quick and easy. You might need to go back to square one and make just one change at a time so you know what the effect is.
I have to trouble shoot the race car and see if it needs something simple (coil, icm, ecm, opti) or a new engine - its my weekend big project
So, let's move along. Why does the D#@n thing run for two seconds then die everytime. Fuel pressure is good and holds. Could the VATS crap be killing my injectors?
Replace the coil and ICM one at a time. I would go for the coil first only because it can be unplugged and just hung in there, it's quick. If symptom is still the same I would them try the ICM. If it won't start, the new ICM might be bad.
But the way I personally would go first is make some tests in the current status before changing any parts. I would try to find out if I am loosing spark or the injector pulses. I would connect a noid light on a injector and a in line spark tester (or grounded plug) so when the engine quits, I then can try to start it and know exactly what I am missing.
I would also ask; after it dies, does it restart right away again, or is there is a wait period before it fires again?
Forget about classic VATS, you would not be able to crank it.
FEDS is part of what VATS activates to inhibit the injector drive. That why I want to see a noid light on there to see by some chance if you are losing injector drive. Something strange could be going on not letting the CCM communicate with the ECM turning on FEDS and letting the injector drive be activated. It is possible the ECM is related to no injector drive which are some known problems.
Just trying to find out what the actual problem area is.
2) The way you now describe the problem is quite different. Are you saying that you can't crank the engine normally with the key but have to ground the relay. Then this starts to sound like a VATS problem. You need to find out firstly why you can't crank the car. It takes 3 minutes from a VATS event for the CCM to reset itself and time out. Every time you turn the key and it does not crank, it starts the clock again.
If it is VATS, then it would affect fuel delivery. The CCM has got to be happy and turn on the ECM to activate the injectors. Wipe the key pellet with alcohol to clean it or better try another key. You can actually clean the 2 contacts in the key cylinder for the key with a Q-tip. The wood ones work better because they are thinner and easy to get in.
If you really can't crank the car normally using the key than that might eliminate the ECM as a problem which is a good thing.
