1988 Engine Status Codes
Old May 25, 2011 | 05:41 PM
dsmithh's Avatar
dsmithh
Default 1988 Engine Status Codes
The Check Engine Soon/Now message on my 1988 has been appearing intermittently over the past week, with no problems in performance noted. Is there a way to determine the event that is causing this message to appear?
Old May 25, 2011 | 06:30 PM
vader86's Avatar
vader86
A code reader or paperclip will flash the SES lamp to show the code, if it remains set. Run a search for "paperclip trick" and you'll see how its done.
Old May 25, 2011 | 07:37 PM
floridamale's Avatar
floridamale
1985-1991: ECM Codes
Code #12: Normal No Codes.
Code #13: Open Oxygen Sensor Circuit.
Code #14: Coolant Sensor Circuit Low.
Code #15: Coolant Sensor Circuit High.
Code #21: Throttle Position Sensor High.
Code #22: Throttle Position Sensor Low.
Code #23: Manifold Air Temperature Circuit High.
Code #24: Vehicle Speed Sensor.
Code #25: Manifold Air Temperature Circuit Low.
Code #32: EGR System Failure.
Code #33: Mass Air Flow Sensor High.
Code #34: Mass Air Flow Sensor Low.
Code #36: Mass Air Flow Sensor Burn-Off Function Fault.
Code #41: Cylinder Select Error.
Code #42: Electronic Spark Timing.
Code #43: Electronic Spark Control.
Code #44: Lean Exhaust indication.
Code #45: Rich Exhaust Indication.
Code #46: Vehicle Anti Theft Fault.
Code #51: Faulty Mem-Cal.
Code #52: Fuel Calpak Missing.
Code #52: (1990-91 Corvette Only): Engine Oil Temperature Sensor Low.
Code #53: System Over Voltage.
Code #54: Fuel Pump Circuit Low Voltage.
Code #55: Defective ECM.
Code #62: Engine Oil Temperature Sensor Circuit High.
Old May 25, 2011 | 08:33 PM
dsmithh's Avatar
dsmithh
Thanks for the info! Is there a way to prompt the car to report what codes it has, or is this only done with a special device?
Old May 25, 2011 | 11:00 PM
vader86's Avatar
vader86
As I said above, a paperclip will do the job. Search in the archives for paperclip trick.
Old May 26, 2011 | 09:47 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://www.corvettephotographs.com/c4vettes/ecm.htm
http://members.shaw.ca/corvette86/No...it%20Check.pdf
Old Jul 31, 2011 | 01:42 PM
dsmithh's Avatar
dsmithh
Thanks for all the info. I was able to get the code indicating oxygen sensor. I found the sensor and the wire was disconnected! Maybe a previous owner....so I'll just keep me "code tool" handy if the service engine light comes on again.
To 1988 Engine Status Codes
