Uneven camber per side
Old May 29, 2011 | 01:50 PM
Aardwolf's Avatar
Aardwolf
Default Uneven camber per side
When doing an alignment I found I could only get 1.2° negative camber on the passenger side but 1.8° on the drivers side. I wondered why and found a shim between the frame ear that holds the upper control arm. It is an 1/8" steel shim and it's only on the drivers side. I took the passenger side apart and found a 1/16" shim will fit in there, to get more and even max camber. I cut out a new shim and made it with bolt holes instead of slots.
I also took material off the conical spacers for more camber. Local machine shops wants $35. I turned my drill press sideways, bolted the part in, and used a hacksaw. It worked out really well!
Old May 29, 2011 | 02:43 PM
oldalaskaman's Avatar
oldalaskaman
something that may help in the future, the threaded camber rods from some of the venders, saves guessing and unbolting, do all adjustments quickly, hope this helps.
Old May 29, 2011 | 04:20 PM
Aardwolf's Avatar
Aardwolf
For the rear? This is for the front. I was happy to find why the camber was uneven. To bad the factory didn't put in the same shim per side.
Old May 29, 2011 | 06:08 PM
oldalaskaman
sorry bout that, I have crs.
Old Jun 5, 2011 | 03:20 PM
Aardwolf's Avatar
Aardwolf
Just in case anyone does this, pic:
It actually cut very well. They turned out within .05" of each other! Around 1/8" was removed. The rear spacer is extremely close to the frame ear now. I will update the thread with how much camber change this achieved. Heading for an alignment this week. Just by looking at the wheels, there is more camber!
Old Jun 5, 2011 | 03:55 PM
DanZ51's Avatar
DanZ51
Are you making a bevel (conical) cut that way? Got an after picture of the conical spacer after the cut?
Old Jun 5, 2011 | 05:57 PM
Aardwolf's Avatar
Aardwolf
I cut off almost all of the straight part on the rear spacers, not the coned side. I took an equal amount off the front spacers. The bolt tool I made shows both rear spacers in the pic, one on each side to make them fit well. It was a good idea that cost nothing and I can clearly see more camber in the wheels now.
Old Jun 5, 2011 | 06:18 PM
littlesk8cracker's Avatar
littlesk8cracker
i recently had my car aligned, and one side ended up being like 2 shims while the other took like 6?! i was a little confused there
Old Jun 5, 2011 | 06:33 PM
Aardwolf's Avatar
Aardwolf
Probably different thicknesses on the shims. It can take some trial and error to get the right spec using different sized shims.
Old Jun 5, 2011 | 11:00 PM
Churchkey's Avatar
Churchkey
Uneven alignment specs side to side on the front suspension are necessary to compensate for crown of the road on street driven cars.
A car will pull to the side that has the most positive camber.
The opposite is true for caster. A car will pull to the side that has the lesser ammount of caster.
1/2 degree combined pull to the left works well on the '90. IE: left front camber 1/4 degree more positive than right front. left front caster 1/4 degree less than right front.
The size of the shim stack is irrevelent within reason as long as the alignment is correct.
Old Jun 5, 2011 | 11:09 PM
mike100's Avatar
mike100
I sometimes wonder how square some of these C4 frames are...like a heavy model with high spring rates that got driven with the targa removed frequently.
I recently saw a 91 where the clamshell hood was just touching the door, but the nose alignment was spot on with the body gap.
Old Jun 6, 2011 | 12:54 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Have you consider off-set LCA bushings?
Old Jun 6, 2011 | 01:57 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Years ago an alignment shop tried to tell me that.
Problem was I drive the fast lane and the crown goes the other way.
Old Jun 6, 2011 | 09:03 AM
Aardwolf's Avatar
Aardwolf
I did but they are $110 plus shipping compared to $0. I should get enough camber with just the spacers cut. I'll find out this week.
Edit, wasn't able to get the car aligned. The shop found the wheel bearings to worn. I brought it home and put spares on and checked the alignment myself since that was Friday and I had to run it on Monday. Looked like 2.5° camber from this mod. The car handled SO much better!!! Pretty new to DIY alignment so I'll have a shop check it at some point.
To Uneven camber per side
