have a tricky one for you
Old Jun 1, 2011 | 11:15 AM
engle1147's Avatar
engle1147
Originally Posted by frenchyoliver
My buddy has a 90 .
For months now he is loosing coolant fluid ( about 1 liter every 150 miles)
BUT...
No white smoke, exept like 2 seconds while starting cold.
No smoke at all while hot... Car runs great.
Nothing is falling anywhere...
Plugs color are OK. None are cleaner than any others...
Water pump is new...
Nothing can be seem....
Kind of real strange.
Check the heater core for leaks.
Old Jun 1, 2011 | 10:08 PM
jfb's Avatar
jfb
I couldn't find a slow leak until one day I came home and opened the hood after shutting the engine off and coolant was very slowly dripping onto the exhaust pipe and evaporating before it reached the ground. The head gasket was leaking. If you need new head gaskets, buy the
Fel Pro teflon coated gaskets, they seal much better and last much longer than non coated head gaskets.
Old Jun 10, 2011 | 02:58 PM
FF1wms's Avatar
FF1wms
St. Jude Donor '11-'12-'13
Originally Posted by AGENT 86
Pressurize the cooling system and see what you can find.
With a big enough leak, you put that dye in and when you turn on the black light it will look like someone poured a bucket of dye under your hood and you can't tell where it's all coming from.
Old Jun 11, 2011 | 10:31 PM
the blur's Avatar
the blur
Send the oil out for analysis. They'll know right away.
Old Jun 12, 2011 | 01:01 AM
TheCorvetteKid's Avatar
TheCorvetteKid
Originally Posted by bill mcdonald
when my 90 did this trick it was the head gasket
Same on my '89.
Very typical problem with '88 to early '90 C4s. And chances are your friend's car won't experience the full-blown head gasket problem until after he lets the car sit for a while (like over the winter).
Old Jun 12, 2011 | 02:21 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Originally Posted by leesvet
nope....
Le PePBoys
BWWAAAAAhahahahaha!
