LSX 454 In C4
Old May 30, 2011 | 07:52 PM
JohnnyFive's Avatar
JohnnyFive
Default LSX 454 In C4
Has this been done? Google search hasn't found one.
Old May 30, 2011 | 10:28 PM
cv67's Avatar
cv67
St. Jude Donor '05
id love to see that done, had my eye on that motor for awhile!!
Do it! Cubes +LSX platform how can you go wrong.
Old May 30, 2011 | 10:39 PM
JohnnyFive's Avatar
JohnnyFive
Just how difficult would this be? A SBC 427 would be $2500 less...what else would I need over a Gen 1 swap? Just an ECM and diferent headers?
Obviously the intake would be different but the LSX intake is about the same price as a mini ram.
Old May 30, 2011 | 10:43 PM
cv67's Avatar
cv67
St. Jude Donor '05
That LSX will make more power reliably than a Gen1 sbc ever will you get what you pay for there.
If the dimensions are the same as a sb LSx sure it could be. Guys have stuffed BBC in a C4 dont know why that one couldnt fit also
Old May 31, 2011 | 12:53 AM
JohnnyFive's Avatar
JohnnyFive
The LSX 454 is supposed to have the same outer dimensions as any other LS engine, so it will fit.
Just wondering how much more expensive the swap would be over an SBC swap.
Other than beefing up whatever breaks at 600HP, Id also need an LS compatible ECM, accessories, headers.
Anything else I'm overlooking?
It is a wcked cool engine. They build them not more than 10 miles from my home, at the Livonia performane engine facility.
Read quite a bit on the build, very good quality control at the General.
There's a vid on YouTube where they spray an LSX 454 on a dyno. It makes 820 horses but even more impressive is the fact that it revs to about 8200 RPM!
That LSX would make my C4 so fast I'd get kicked off the dragstrip until I got a full cage, lol.
Old May 31, 2011 | 10:51 AM
cv67's Avatar
cv67
St. Jude Donor '05
Depends if you carb it or not. Fuel delivery gauge functions accessory drives are something to consider.
For the 7-8 you were looking at spending maybe a large CI sbc gen 1 is your ticket. Still cost more with exhaust injectors tuning etc but will be much simpler. No reason you coulnt put the car in the 10s or 11s without trying too hard.
So how much on minimum CC payments could you make every month
Punt
Old May 31, 2011 | 11:54 AM
yedister's Avatar
yedister
You really should learn to use google. I have provided a list below from my stock ( I have kept a list of C4 LS conversion) for your reading pleasure. There is plenty of imformation from these post, there are detailed builds and pictures also. I highly suggest that you save these post in a file on a cd rom for future reading. You can put them in a word document or print them as a PDF file.
If you are going for a 454 CI, make sure it makes at least 750 HP. because of the 12 degree heads. The whole motor build / swap will be expensive but do it once correctly and be done. There are ways to get quality engine parts cheaper if you are not getting a crate motor.
Some of there are the same build on different boards, the good point is that more people got a chance to ask different questions.
http://www.ls1tech.com/forums/conver...-corvette.html
http://www.ls1tech.com/forums/conver...ject-pics.html
http://www.ls1tech.com/forums/conver...wap-build.html
http://www.ls1tech.com/forums/conver...orvette-2.html
http://www.digitalcorvettes.com/foru...ad.php?t=62126
http://www.vetteworksonline.com/c4_c...conversion.htm
http://forums.corvetteforum.com/c4-t...ith-4l60e.html
http://forums.corvetteforum.com/c4-t...vail-soon.html
http://forums.corvetteforum.com/c4-z...sx-motors.html
http://forums.corvetteforum.com/c4-t...-early-c4.html
C4 LSx Engine Swap Headers (http://www.melroseheaders.com/)
http://www.corvetteactioncenter.com/...p-build-2.html
http://www.smokinvette.com/corvettef...ad.php?t=33667
http://www.vettaid.com/LSxPackagesKits.aspx (Adapters)
http://www.carcraft.com/techarticles...NTERSTITIAL_15
http://tech.corvettecentral.com/2010...-c4-corvettes/
Old May 31, 2011 | 03:23 PM
JohnnyFive's Avatar
JohnnyFive
I'm pretty sure I've read all of the articles you've posted links to.
I wasn't asking if anyone has done an LS swap in a C4, I was asking about the LSX 454 crate engine from GMPP
The LS swap articles made the project sound relatively easy, but the articles I read used a 5.3l truck engine for the swap.
Just trying to find a more specific example. I believe the LSX 454 is a tall deck block , so there could be fitment issues, hood clearance, headers, etc.
I've actually seen that engine up close and personal at the Detroit Autorama and it is just a pinch taller than an LS3 or LS7.
Old May 31, 2011 | 09:52 PM
yedister's Avatar
yedister
Why didn't you just ask "What is the deck height of LSX 454 from GMPP?"
The standard lsx 454 is a short deck.( 9.240 deck height) The lsx454r is a talldeck (9.720 deck height)
Old Jun 13, 2011 | 01:53 PM
JohnnyFive's Avatar
JohnnyFive
Just discovered that Rocland Standard sells a nifty bellhousing to mate my ZF to the lsx....
Saving my duckets and thinking it over...
Old Jun 13, 2011 | 01:59 PM
cv67's Avatar
cv67
St. Jude Donor '05
If it doesnt fit, make it. Thats hot rodding...way to have something unique.
Not a total bolt in deal anyway might as well go the distance.
Old Feb 7, 2012 | 04:50 PM
JohnnyFive's Avatar
JohnnyFive
The more I think about it, the more I want to put this engine into Alice (my '89 Vette. If yours doesn't have a name you don't really love her).
The other engine I'm considering is a Motown lite 427. The cost for the lsx build would be just a bit more expensive, because of the new accessories, bellhousing, computer, etc.
I dunno, both options have so many selling points.
Decisions, decisions.
Old Feb 7, 2012 | 05:10 PM
383vett's Avatar
383vett
You're going to put an LSX 454 into a Corvette named Alice? At least rename the car Pat or Chris.
Old Feb 7, 2012 | 05:38 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Old Feb 7, 2012 | 07:02 PM
LD85's Avatar
LD85
Sue possibly? Johnny Cash would be proud
Old Feb 7, 2012 | 08:22 PM
1985 Corvette's Avatar
1985 Corvette
Johnny, you pull the trigger on this and you will go down in C4 Tech history as having the baddest engine swap ever. All motor, brand new 7.4 liter V8 that's an LS?
DO IT! Do for those of us who can only dream it. What kind of FI intake can feed that monster?
On a side note: this engine makes me wonder why one would cough up 14 grand for a LS7 that is down 100 ponies by comparison.
Old Feb 7, 2012 | 09:18 PM
Black89Z51's Avatar
Black89Z51
Suckin' gas, haulin' ass.
On an engine like that, I would go with Mozez heads and a sheet metal intake. I only know of one other motor bigger than that, and that's an RHS 460 going into an Fbody. Once you get to a 4.100" stroke, you're really putting some serious side-pressure on the pistons.
To LSX 454 In C4
Old Feb 20, 2012 | 02:53 PM
-WhItE_NoIsE-'s Avatar
-WhItE_NoIsE-
LMR has a 502 RHS
Old Mar 23, 2012 | 01:38 AM
Skivette1's Avatar
Skivette1
Im doing the swap as we speak. It will be done May 1st give or take a few days. I'll post picks. Car and parts are at shop as I type this.
Old Mar 24, 2012 | 09:00 AM
IAFF alumni's Avatar
IAFF alumni
Looking forward to May 1st!
