Electric Water Pump
Old May 31, 2011 | 12:56 PM
matt_jahn's Avatar
matt_jahn
Default Electric Water Pump
I installed an Electric water pump about two years ago. one of the seals on my timing cover has been leaking so when i was looking at that i noticed coolant coming from the weep hole in the water pump. Its been a while so i dont remember exactly how i installed the electric water pump.
does this mean the freeze plug or whatever i put in was installed incorrectly or do i need a new water pump and put the electric motor on it? im going to take the old water pump off tonight and take it apart to see what i find. but any advise in the meantime would be appreciated.
Old May 31, 2011 | 01:18 PM
STL94LT1's Avatar
STL94LT1
The small freeze plug you installed in the rear of the pump housing should have closed off the weep hole.
Old May 31, 2011 | 02:15 PM
matt_jahn's Avatar
matt_jahn
ok thanks, i just couldnt remember for the life of me. so i should be able to take it out and put a new freeze plug. that saves me about 120 bucks
Old May 31, 2011 | 02:31 PM
turbotim23's Avatar
turbotim23
Well since you already have the electric water pump in there now it should be a lot quicker to fix the pump this time. If you don't want to put anther freeze plug in there I've heard of guy's JB welding a Quarter over the hole, I guess a Quarter is just about the right size and JB weld is great stuff to fix things like that. I'm sold on it, had great luck fixing many things with it!
Old May 31, 2011 | 02:40 PM
STL94LT1's Avatar
STL94LT1
^^^ You must be thinking about the timing cover, a quarter won't work in the water pump housing.
Old May 31, 2011 | 02:54 PM
turbotim23's Avatar
turbotim23
You might be right it's been a while since I read about doing a electric water pump. You could always JB weld over the new freeze plug to make sure it doesn't leak again .
Old May 31, 2011 | 07:09 PM
matt_jahn's Avatar
matt_jahn
I was thinking about liquid Teflon or maybe some rtv on the freeze plug before installing it.
To Electric Water Pump
