So I have an 89 Trans Am GTA with the 5.7. 38k miles. Completely stock. The problem is it runs rich once warm, around 160-170 is when it starts running very rich; to the point of black smoke. The car runs perfect when cold. The engine coolant temp sensor and o2 sensor had been replaced. All other sensors seem to be working fine including the MAF. Injectors ohm out fine. I checked fuel pressure and its at 41-43 psi. The kicker is the pressure drops kind of fast, with in 5 minutes the fuel pressure is around 36-38 psi after the pump kicked on. Goes down to about 28-30 psi after 15-20 mins. This sound like a leaky injector? Any other ideas? Oh, and no codes.
Those pressure readings are not too bad. At least not bad enough for what you are experiencing. JMO
But if they are the original injectors it won't take much money and time to swap them out.
Next time your GTA is fully warmed up/ coolant temp hot & starts to act up....
Recheck all 8 Multec fuel injectors before the engine has a chance to cool down ( within 10 minutes).
Those GM Multecs 9 out 10 times resistance check very much different Hot from cold readings.
Sometimes as much as 9 or 10 ohms difference.
Sometimes they near dead short out( internal bobbit copper coil windings) after HOT.
You may read some near 1 or 2 ohms or even "0".
Speak from almost 20 years of experience troubleshooting & repairing GM Vehicles with "MULTEC" style fuel injectors.
C4 of Year Winner (appearance mods) 2019
Originally Posted by 87 vette 81 big girl
Recheck all 8 Multec fuel injectors before the engine has a chance to cool down ( within 10 minutes). Those GM Multecs 9 out 10 times resistance check very much different Hot from cold readings. Sometimes as much as 9 or 10 ohms difference.
Mine showed normal when cold. Two were WAY off when hot. Because one wasn't working on the side where the O2 "sniffs" the mixture, it "thought" the motor was running lean. So, it compensates by increasing injector pulsewidths which adds more fuel.
My cure? I built a 383 and replaced the whole damn motor. THAT fixed the problem!
Thanks for the replies. So what you guys are saying is its most likely the injectors and not something else I haven't thought about? I wouldn't think a week coil or ignition module would give me the symptoms I'm talking about.
Just went thru this with my 95 LT-1 Corvette. Multi-Teq's were leaking at 85K miles. Call Jon Banner at FIC, 770-888-1662 and talk to him about either new or rebuilt Bosch Gen III injectors. Simple change out and my car has never run that good and smooth. I should have done this years ago when I first bought her. Rebuilts are $189 and new Gen III's are $339. Based on the experience sited on this Forum I chose the rebuilts. Good Luck.
Have you checked the ECM for stored trouble codes?
Have you changed/cleaned the MAF sensor recently?
It could be a failing injector but your indicating the car is fine in "open loop" but once the car goes into "closed loop" you have a "rich" problem (black smoke) so to me it seems more than likely you've got a bad/wacked out sensor in the mix.
Same issues as yours same yr, symptoms. etc
It was the injectors. Dont even bother trying to clean them.
Toss them in the trash and replace.
Don't throw them (injectors) away. I believe I heard FIC will buy them and give you trade-in credit. Check their website for details. If not them, someone will probably give you a couple bucks for them.
