93 running hot
Old Jun 10, 2011 | 12:02 PM
surfer93's Avatar
surfer93
Default 93 running hot
Can't use my A/C because car goes up into the 240's quickly on a hot day in traffic, car has new coolant and coolant is full and both fans are working.
T-stat is realitively new, but was wondering if anybody ever had one not open all the way?
Or could my WP be going south?
Old Jun 10, 2011 | 12:14 PM
1986coupe's Avatar
1986coupe
How old is the rad? It might be time for a new one since the rad is what transfers the heat away. The water pump may not be performing to the best of its ability. Sometimes with cooling systems when you replace one thing it causes problems in other parts of the system. Sometimes best to replace rad, water pump, and even hoses all at once. Then you know that the system is working properly.
Old Jun 10, 2011 | 12:58 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
How's your idle? A bad EGR will cause it to run hot, no exhaust gas returning to help cool the engine.
Old Jun 10, 2011 | 01:06 PM
surfer93's Avatar
surfer93
Radiator is 3 yrs old and EGR is disconnected, as I have headers.
Headers have been on for 4 yrs and never had this problem.
Old Jun 10, 2011 | 02:40 PM
desertmike1's Avatar
desertmike1
did you pick up a plastic bag...?
did you check the area in front of the radiator...?
Old Jun 10, 2011 | 02:59 PM
Rag Top's Avatar
Rag Top
Coolant/water balance? My '62 is VERY sensitive to the mixture.
Dirty radiator fins?
Old Jun 10, 2011 | 03:11 PM
pcolt94's Avatar
pcolt94
WP is probably OK. I have had similar problem and is a classic symptom of a bad stat. I would get a LT1 stat and go from there. If it does not open enough it will cause you problem.
After that I might look at the radiator but they usually go bad slower over time.
The other side of the coin is a blow head gasket. You could get a kit from a parts store to check for exhaust gases in the coolant.
Old Jun 10, 2011 | 04:24 PM
surfer93's Avatar
surfer93
The Hoover might have picked up something it should not have, but I do not think so.
Going to replace the T-stat, if that does not work. PColt you owe me $13 for this.
Last month Advance had a big sale, now all their parts are really high, bought a window regulator for daughters car at Rock for $84, Advance wanted $193.
To 93 running hot
