Mass Air Flow Meter problems....
Old Jun 17, 2011 | 01:25 AM
RicG's Avatar
RicG
Default Mass Air Flow Meter problems....
I have an 89 Corvette, I haven’t had the car very long and I am trying iron out a few problems... One being the Mass Air Flow meter. I discovered recently that the meter is disconnected. The car is running a little rough from time to time so I thought by connecting back it would it would make an improvement... Quite the opposite, I could barely get it started and it wouldn’t even idle.
I have read about other meters that have an effect on performance so my concern here is if I replace the MAF meter and the relays will this fix the problems I am having and also make the “Service Engine Soon” light shut off??
Is there anyone who has had a similar experience? Also I am in Australia so I will have to by the parts online so I need to know where is a good online shop for parts.
Old Jun 17, 2011 | 01:53 AM
Pwnage1337's Avatar
Pwnage1337
Replace the relays before replacing the actual sensor itself. You might get lucky.
Old Jun 17, 2011 | 02:27 AM
RicG's Avatar
RicG
Thank you.... Thats a good idea but the unit looks like a reconditioned one as the is silocone sealant around the casing.
Old Jun 17, 2011 | 08:23 AM
Pwnage1337's Avatar
Pwnage1337
You're right, it is more than likely to be a Reman'd then. Being down in australia maybe you would just order both relays and the sensor itself and be done with it, that way you wouldn't have to wait for a new MAF is you replaced the relays and that didn't do the trick.
Old Jun 17, 2011 | 09:29 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
The relays are on the firewall, not sure if they moved them on your conversion, but I doubt it.
MAF code diagnostics from my 86 FSM
http://members.shaw.ca/corvette86/Code%2033.pdf
http://members.shaw.ca/corvette86/Code%2034.pdf
http://members.shaw.ca/corvette86/Code%2036.pdf
How to retrieve ECM codes
http://www.corvettephotographs.com/c4vettes/codes.htm
Old Jun 17, 2011 | 10:02 AM
Kool88vette's Avatar
Kool88vette
If you need the sensor. I have a new one like this in the box. http://www.mamotorworks.com/corvette?frame=3.7287
PM sent
Old Jun 17, 2011 | 08:46 PM
RicG's Avatar
RicG
Thanks, I am going to replace the lot.
Old Jun 17, 2011 | 08:47 PM
RicG's Avatar
RicG
Thanks for the info Agent 86.... I will need some time to go through it.
Old Jun 17, 2011 | 09:05 PM
Tony A.'s Avatar
Tony A.
Please provide updates for when you figure this out...would like to know what you do to fix it.
Old Jun 17, 2011 | 09:13 PM
icemaidenz's Avatar
icemaidenz
hi i was having issues from hell as well code 33 fuel pump running rich etc etc bought a new boche 1200 map and well still wont start soooo im going to throw a bowl and carb and be done with the whole thing so i have a new boch map sensor if your intereted
Old Jun 18, 2011 | 04:13 AM
RicG's Avatar
RicG
Tony A... It will take a while as I have source the parts from the US... But yeah I will keep you posted.
I really hope the MAF and relays will fix the problem as it is not running the best and I think it is running a bit rich as the exhaust is black on the pipes. It is difficult to start especially when hot.
Fingers crossed....
RicG's Avatar
RicG
Icemadenz,
I PM you....
Old Jun 18, 2011 | 11:17 AM
Tony A.'s Avatar
Tony A.
Fingers crossed....
A guy in "Parts for Sale" is parting out his 88. He has a MAF sensor (screens removed) he's asking $70 for but no one is really responding yet so I'd bet he take a little less.
http://forums.corvetteforum.com/c4-p...tc-88-car.html
Old Jul 5, 2011 | 08:39 AM
RicG's Avatar
RicG
UPDATE...
I got my new / second hand MAF... I also have ordered parts from the US (relays)...
I didn’t wait for the other parts... Got home early from work and in my inpatients installed the MAF and it works fine and it seems to run a little smoother than having the old MAF disconnected. I could barely get it to start with the old one connected up as it was faulty. Strange though it took a little time to settle in but when it did, it starts hot easy as and the biggest of all at the moment the "Service Engine Soon" light turned off. So cool.... It idles a little rough, so I guess I just need a tune as the previous owner didn’t do much to look after it. So hopefully all is good for now.
Old Jul 5, 2011 | 08:45 AM
RicG's Avatar
RicG
A thanks mate.. To Kool88vette...
Old Jul 5, 2011 | 10:02 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
UPDATE...
It would be normal for it to take time to "settle in". The ECM is correcting it's values based on the new MAF. Glad you got it fixed.
Old Jul 25, 2011 | 11:44 PM
AllCaucasianC4's Avatar
AllCaucasianC4
3rd Gear
Default MAF problems on 88 c4
Just started driving a garage kept 35th anniversary vette (88k) and has had the same problem since started driving. When going into a "limp mode" (service light appears) the car will barely make it up hills without playing with the pedal. Letting off the gas gently gets you going, pedal down and the car makes popping sound and does't go anywhere. Also transmission feels jumpy and has hard time passing through gears. Forums tell me MAF and relays. Does this sound like the right match for my problem?
All comments are much appreciated and help make this site the best tool for the job!
To Mass Air Flow Meter problems....
Old Jul 26, 2011 | 07:51 AM
Tony A.'s Avatar
Tony A.
My 88 had a similar problem. Mine turned out to be the fuel pump and fuel filter. Fuel filter was so clogged, the fuel pump would overheat. It would still run but had a real hard time getting fuel to the injectors and would appear to get into limp home mode.
Does your car run ok for like 5-10 mins after cold start then starts acting up? If so, check those items.
Old Jul 26, 2011 | 10:29 AM
AllCaucasianC4
3rd Gear
Default Reply to Tony A.
Yes! runs great cold for the first couple of min then if you hit that pedal the wrong way it goes into that mode. If you have any tips or suggestions for me, lay them on me. Much appreciated.
Old Jun 19, 2018 | 06:52 PM
Zike Gladion's Avatar
Zike Gladion
Cruising
Default Maf code
Hay I have an 86 which is running so rough it can’t even do a burnout. My dad is convinced it’s a vacuum leak but I can’t find it. We unplugged the maf to check it and the vette would idle normally, but it’d throw a code. Then when we plug it back in the code goes away. Is it possible that the maf is still defective?
