Looking to put C5 wheels on my 96'. If I stagger 17" front, 18" rear and run different diameter tires will I have problems with ABS or traction control? If so, whats the limit on front/rear diameter difference? Thank you for your input.
From: One day you're a Comet...the next day you're dust... Arkansas
You shouldn't have abs or tc problems. You are limited by clearances. You will effectively raise gear ratio. (lower numerically). Mounted tire diameter will differ between individual tires. You will impact handling (probably negatively). You limit rotation options with different sizes. IMO for a street car there are more negatives than positives.
Thanks for the quick reply. I am not looking to go crazy with the difference in dia.'S maybe 1". I just don't care for the real low profile tires on rear like 35 that you would nneed to get close to a 45 in the front. I will lower the rear abit if needed to cut down on the rake.
My '94 has been running 18" C5 thinspokes in the rear, and 17" in the front, for as long as I've owned it (since 2004). I've had no problems with TC or ABS. The only downsides (both very minor) in my case have been:
1. Speedometer is slightly off. Reads two or three MPH low at highway speeds. I'm aware of it, and calibrate it out mentally.
2. On rare occasions, when the rear suspension goes into full compression, the inner edge of the rear tire treads kiss the inner fenderwells of the car. It has caused no problems.
Watch the diameter, and keep it as close to stock as possible, and you'll minimize both of these issues.
Most C4s used different tire sizes (of the same rim diameter), so rotating them front-to-rear isn't really an option anyway.
PM me your email address. I put a spreadsheet together that will let you calculate overall tire/wheel diameters for comparison. It does not acount for offset.
Stu.
If you go to www.miata.net they have an online tire size calculator.Very handy guide to compare tire sizes so you can see the height differences.Also tells you how much your speedometer will be off,fast or slow.this should be all the info you need for a correct choice.i put C5 wheels on my C4 and the 285/35 18 was almost a perfect match for the 285/40 17 tires my car came with from the factory.Hope this helps!
On average (varies slightly between tire brands), there is only 0.12" difference in the overall diameter between these two tires.
You won't even notice a difference in the speedometer keeping the size that close.
If I´m not mistaking the difference in diameter between front and rear shouldn´t be more than 5 %. Could be different for different cars.
The ABS system keeps track of the wheel speed on all four.
Depending on how the system is programmed, if the system is programmed with different sizes on front and rear, you can´t change either to similar size front and rear.
I´m sure there is someone that can verify this or explain better.
But, as stated before, there are some calculators on the net so you can find out what tire to use when you go bigger in wheel size.
You are correct in the fact you don't want to change overall diameter more than 5% (or close to that number anyway).
But if he uses the listed size above (285/35-18) and keeps his stock 255/45-17 front tire he will be fine.
The ABS sensor won't know the difference between the stock 285/40-17 rear, and the new 285/35-18 rear.
They are only 0.12" different in overall diameter, with the 18" being .12" shorter.
Thanks everyone for the input and info. Again, my biggest concern is different overall diameter differences front to rear. If I know the stagger limit if any, I can choose from many wheel size/tire size combinations within that limit of overall diameter difference. If as one response said I need to stay within 5%, that means with a 26.0" dia on the front, I would need to go no more than 27.3" on the rear. Does this sound right?
Reason: added info
