help tpi tp carb
Old Jun 17, 2011 | 09:20 PM
icemaidenz's Avatar
icemaidenz
Default help tpi tp carb
hi im in nova scotia we dont hve smog emmission tests etc to tend with for over a month now ive had the vet from hell code 33 spend hours testing and checking grounds replaced burn of mod and bought new map sensor boche one that cost a damn arm and leg still throwing code 33 was running real rich backfiring out the rearend first now backfiring into the intake now its turning over and not starting...replaced the fuel filter tested pump fuel rail etc etc finualy said to self enough is enough now i am simply going to get a bowl and carb and get rid of the whole tpi comuter nightmare.
soooo i have an 85 manual stock what do i need part wie to do this
ie do i need a different fuel pump distributor etc etc
earlier tonight i was busy taking off the twp headers and throttle body sooo i now have a ton of parts too including 2 burn off mods and maps that are fu=ine fuel rails header etc sooo if anyone is in need let me know
so anyone out there change from tpi to carb if so can you tell me what i need
thanks
deb
Old Jun 17, 2011 | 11:25 PM
1986coupe's Avatar
1986coupe
Did you check the plastic vacuum lines on the engine?
Is the timing set properly?
What is the condition of the air filter?
Try this. Unplug the MAF sensor and see how the car runs. If it changes then you might have a problem in the distributor. If it doesn't then the problem is elsewhere.
Sorry but it drives me crazy when I read that people want to put a carb on a TPI.
Old Jun 18, 2011 | 07:16 AM
icemaidenz's Avatar
icemaidenz
Default replay
[QUOTE=1986coupe;1577909058]Did you check the plastic vacuum lines on the engine?
actually i noticed one broke after i took off the heads
timing is fine
air filter was fine but was just replaced preior to the nightmare
i unpluged it at first made a differnce later on it didnt make a difference.
i know its not ideal but im a single mom that saved for four years i had the money in savings account makin a whpping 8 bucks an hour sooo i figured playing with a vet was worth the 8 bucks a month and if i ever needed to i could resell it...lol providing its running lol. Soooo hours and hours of fruitless labor at a shop i can not do.
Old Jun 18, 2011 | 07:42 AM
BTTB's Avatar
BTTB
Default carb
Go to --thirdgen.org---click on technical articals---all info that you are looking for.--
Old Jun 18, 2011 | 08:10 AM
mmracecars's Avatar
mmracecars
I myself would stay with the tpi,if you want to go the carb way,i converted my 84 to a carb.you need a regular hei distibuter(bought a new one on ebay for 60),a low profile intake(something like a performer),carb(i used a 750 vac sec,already had it),bought an edelbrock throttle cable bracket to hold the throttle and trans t/v cable,i used a holley regulator cause the crossram is only 13 psi.you might need a bypass style regulator to reduce the fuel psi down to 7 psi.heres a photo.
mike.
Old Jun 18, 2011 | 06:50 PM
Crepitus's Avatar
Crepitus
nice n clean Mike. How about a pick of the throttle linkage? Did you get it all undet the stock hood? Thanks.
Old Jun 18, 2011 | 08:45 PM
mmracecars's Avatar
mmracecars
just sold the car and bought a procharger for my 95 ,only have one other engine pic.the throttle bracket i got from summit,edl-8036,bought a cheap summit drop base air cleaner
it would just barely touch the hood went fully closed.
mike
To help tpi tp carb
