Hot Lt-4
Old Mar 25, 2012 | 10:04 PM
  #41
aminnich's Avatar
aminnich
Nevermind, somehow I missed the post on page two where he figured out what was wrong. My bad.
Old Mar 26, 2012 | 05:54 PM
  #42
radar502's Avatar
radar502
Originally Posted by mandingo214
Reading this thread, and living in Dallas, I would also like my car to run below 200 in traffic. Once the fans click on, it never gets over 235, but I like the idea of it never getting above 200.
What does it take to reprogram the ECU to have the fans kick on at 180 and 190? If it takes a shop, any recommendations for a shop in the north Dallas area? If the ECU is reprogrammed, does that keep the Check Engine (or whichever trouble light) from clicking on?
Thanks.
What year is your's ?? I'm in Houston don't know anybody in Dallas ..Call Corvettes of Dallas ask they might know somebody there ..there's more Corvette shops in dallas that in Houston that will be a start.. You can send your Ecm to somebody or just drop it off don't need the Vet. to do it ..I did the hole 10 yards to mine but turning the fans on sonner is easy thing to do and it will help some if all in good shape..The 96 is set up to run @235 so unless you make fan changes it gona be 235 witch is ok if that's all it goes to ..Mine just worn out Rad. and need just to be redone cleaned Etc. Theres lot's you can do take the top off (the shroud) and clean it out blow the A/c condencer out ...That may help ..Go to radar502 you can pic of mine..If you can find a cheaper Rad. that i did it not that much to chang it over to one that will run under 200 with air on... I love mine..Done that..Hope this helps...
Old Mar 26, 2012 | 05:58 PM
  #43
radar502's Avatar
radar502
All most forgot the A/c compressor was week in mine and it trying to keep up with the heat run the temp up 10% more ..After I put a new compressor on the temp droped about 10-15%.. Go figure...
Old Mar 26, 2012 | 07:52 PM
  #44
mandingo214's Avatar
mandingo214
Thanks Radar502. Mine is an LT4. I read through the Tune/Scan section, which is not much help for the OBDII cars.
There is a dyno tune place in McKinney, where I live, so I am going to see if they will make the change for a reasonable price. Running at 235 probably does not impact performance, I just think cooler is better once it starts getting hot outside.
Also, the disparity between the analog and digital temp meters makes me trust neither. I basically just watch the oil temp.
Old Mar 27, 2012 | 05:40 PM
  #45
radar502's Avatar
radar502
The 96 LT-4 is way happey with the temp @185-200..Let me know what is the deal with the tune place I am going to have mine retuned after somemore work soon.. I here Hight $$ to have one tuned in Houston .I payed $150,00 in Bation Rouge last year ..I her $500.00 in Houston??? need any help let me know...
Old Mar 29, 2012 | 11:20 PM
  #46
mandingo214
The local shop came back with $200 to program new fan trigger points, which I guess is towards the bottom of your range. If they had said $50, I would go in and have it done. $200 to change something that GM did not see as a problem has me holding off. Is this something more involved then just changing a couple of data points in a file?
I plan on talking with them about a dyno tune, and will ask them to include the fan changes at the same time. Hopefully get a better deal.
Old Mar 30, 2012 | 05:26 PM
  #47
radar502's Avatar
radar502
I don't think it's worth it . I had mine retuned .It had some boltons few and ye ha after the tune.Yes I would do it all at the same time... I look and see if I have the name of the shop in Baton Rouge.. I redone the retire cooling Sys. on mine so I had to have the fans redone..If not broke don't fix it.. Let me know how the tune comes out..
Old Mar 31, 2012 | 09:52 AM
  #48
radar502's Avatar
radar502
These people did my tune ..I
your cart: 0 items, $0.00
Login | Register
Home
Products »
Tuning Services
News & Notes
Contact Us
l l[1][2][3]»
Welcome to Engine Power Systems
We are a leader in advanced EFI engine innovation. From cutting-edge camshaft and valvetrain development to superior tuning of EFI computers, Engine Power Systems is your one stop shop. EPS is owned by Geoff Skinner, co-founder of Thunder Racing. During his 13 years at Thunder, Geoff managed the engine shop, developed their extensive line of custom camshafts, and was the chief tuner of EFI applications.
Engine Power Systems was created with the high tech racer in mind. Never settling for the status quo, EPS is constantly creating new engine combinations that raise the standard for extracting the most power while using the least amount of fuel. It’s all in the combination of parts and the calibration behind it. With an in-house chassis dyno and software to accommodate nearly all brands of operating systems, EPS can tune your vehicle to perfection.
Custom PCM Tuning for Your:
•2010 Camaro SS
•1997 & up Corvette
•2004 & up Cadillac CTS-V
•1993 to 2002 Camaro or Firebird (GM F-Body)
•2008 & up Pontiac G8 GT
•2004 to 2006 Pontiac GTO
•2006 & up Trailblazer SS
•1999 & up GM Truck
•Chevrolet SSR
•1994 to 1996 Impala SS
•and more!
learn more »
Latest Products
Four Star Ultimate Spray Wax Plus
$17.99
Four Star Ultimate Paint Protection
$29.99
Four Star Ultimate Pre-Wax Cleanser
$17.99
Four Star Ultimate Detailing Clay (200 gram)
$24.99
Contact Us :News & Notes :Privacy Policy :Terms & Conditions
http://www.engpwrsys.com
225.751.8500
Mon - Fri, 9:30 am - 5:00 pm Central
6931 North Merchant Ct.
Baton Rouge, LA 70809
This site is copyright © 2012 Engine Power Systems, 2010 Camaro Parts, 2010 Camaro Accessories, LS1, LS2, LS3, LS6, LS7, LS9 Dyno Tuning, Custom LSX Camshafts, Baton Rouge Louisiana. All rights reserved.
think they do mail stuff..
