need help desperately
Old Jun 21, 2011 | 08:35 PM
leadshred's Avatar
leadshred
Default need help desperately
so last week my brakes locked up in traffic. to make a long story short i rode it home and basically destroyed everything, the brakes overheated and locked on both sides. i replaced both calipers, rotors, pads, and hoses. after that i couldnt get it to bleed, and eventually traced it to the master cylinder, after replacing that i bled the brakes and everything seemed fine. i smelt some burning as i did when they locked up, but it soon went away and i assumed it was grease or something burning off. well now my right front brakes are locking up again, but this time not so bad, i cant feel it, but they get really hot. the left side is right as rain though, and im confused. i re bled the brakes, and noticed that with my foot on the pedal depressing it, i could have the right front bleeder wide open with no fluid coming out. anybody have advice or experience with this? this is my daily driver and if i dont fix it, i cant work to make money to fix it. im hoping its not abs related, because i think that module is expensive
Old Jun 21, 2011 | 08:48 PM
pcolt94's Avatar
pcolt94
The information you get back is based on the year of your car, you need to post it and would a help to fill out the profile.
Could be either a bad flex line or a bad ABS unit. You may have to pull the flex line off to find out. Probbly not a caliper. Did you ever check the clearance on the booster actuator rod.
Old Jun 21, 2011 | 09:01 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Which brakes do you have JL9 or J55?
Did you inspect the caliper brackets and make sure everything was clean and smooth when you put them back together?
If J55 did you use new pins? Use any lube on them?
Something is binding somewhere, or your hard brake lines are corroded on the inside and blocking fluid movement. Brakes are pretty basic
Old Jun 21, 2011 | 09:26 PM
leadshred's Avatar
leadshred
sorry, its an 86, i replaced the flex lines, the caliper and caliper bracket are fine. i cleaned everything, greased the slides and pins, and am stuck
Old Jun 21, 2011 | 10:38 PM
pcolt94's Avatar
pcolt94
I hate to say but on that vintage car, many of those problems were a clogged ABS unit. If the flex lines are new you're probably going to end up at the ABS unit.
Only the hard line is between the flex line and ABS. Keep up the troubleshooting to make sure. Pull the hard line off the ABS for that wheel and see if any fluid comes out when you step on the brake.
Old Jun 22, 2011 | 12:38 AM
Churchkey's Avatar
Churchkey
I have run into rusted closed bleeder screws on old cars, maybe remove it & check that it is clear.
It may be the ABS pump if only one front caliper is dragging.
Old Jun 22, 2011 | 09:53 AM
jaa1992's Avatar
jaa1992
St. Jude Donor '12
Hard lines or ABS has a corrosion issue. Fluid makes it past the obstruction but then the pressure doesn't release.
[SoapBox] one of the problems is people do NOT change their brake fluid. Brake fluid attracts moisture from the air, turns acidic and starts corroding brake lines and parts from the INSIDE. When bits of corrosion break off they can casue one way check valves in the ABS unit or the lines themselves. Please for the love of your car replace ALL the brake fluid every two (2) years![/SoapBox]
To need help desperately
