About a decade ago, the 89's compressor seized and I dropped the coin to convert it to r-134a. This spring, it seized AGAIN.
Earlier in the year, I had a great experience rebuilding a power steering pump on aother car...turned a $500 repair into a $2 one.
I'm kinda wondering if a similar attempt on the vette's compressor wouldn't turn out similarly. A rebuild kit is around $30 online, and I figure that, plus a new accumulator, plus materials and the $15 harbor freight vacuum pump would be the cheapest route.
R-134a hasn't been the BEST conversion, do you think replacing the orifice and going back to r-12 would be worth it? Has a better alternative to 134a shown up in the last ten years or so?
What, nothin? A new compressor is a $500 part, if it's $30 worth of bearings and seals, I figured SOMEONE had done it before. (Perhaps it's cuz Daddy was in hydraulics and I watched him rebuild a LOT of stuff)
Send a PM to Suncr and ask his advice. He'll provide you with sound A/C recommendations.
The only replaceable parts are Shaft Seals and Pulley Bearings which are about 50 to 60 Bucks at NAPA. Anything else usually requires new or someone else's rebuild (sometimes no more than a painted case). Assuming you only have a shaft seal leak, then you might be able to fix it. The problem is that those leaks can groove the shaft and nothing will seal that. You will have to take it apart and mic the shaft to see if there's any damage. I don't know of any source for shafts, pistons, internal seals, etc, though you might talk to the guys at www.ackits.com
Shop around and see what you can find. I found a NOS compressor last summer at a Chevy dealer in Mississippi. He shipped it to me for $165 just to get it off his shelf.
I painted the compressor, applied my old label and installed it.
So, shop around, you never know what you'll find out there hidden in some corner.
..... So ... Why don't you just give it a go and rebuild yours ? ... If you don't succeed you're only out $30 right ? ... If you do win , you can write a report on it ... maybe include some pics ... and possibly inspire another C4 owner to rebuild his own AC system ...............
Rocket, you can get a brand new Four Seasons compressor from Oreilly's for $169..... put a drier and an orifice tube in too. If your bent on doing it cheap, get a set of gages ($39) and a vac box ($15) from Harbor freight. From the original 2.75lb R12 requirement, R134 is .80% as R-12 meaning you'll only need to put 3 cans in or 2.25lb. Make sure you add about 1-1.5 oz oil to the drier and soak the orifice tube with oil before you install it. After you put the compressor in, add the first two cans of freon before starting the car. You can add the last can with it running, just watch your pressures. You shouldn't exceed 235 on the high side and if the system is running right, 35 on the low side. Hope this helps.
C409..... I've done AC work for years and I'm going to put together an AC overhaul video this week....I have a kid that'll help me get it on youtube. I didn't know the C4's were so prone to have AC problems. I rebuilt mine last week in 1.5 hours and $244. That was a brand new compressor ($157), drier ($23), orifice tube ($3), conversion kit ($12)& freon ($11 per can x 3=$33); add 7% tax..... Since I had the gages and vac box, that didn't count.
For the Harrison R4 ('84 to '87), they're cheap enough, so I'd just buy new.
Don't know of any internal suppliers for either compressor - shaft seals and gaskets is about all that's available and there are no published tolerances.
Converting to R-134a really affected the cooling ability of the system. To make matters worse, I added a big motor, a loose torque converter, and coolers for both of them ahead of the A/C condenser. Above 90 degrees or so, the A/C goes away, I suspect because they're not enough airflow on the cooling stack to reject all the heat. (Turn the A/C off, and everything returns to normal)
Which makes me wonder if going BACK to R-12 wouldn't be a bad idea....unless having better rejection of heat means the cooling stack would be overwhelmed at 85, instead of 90 degrees?
I'm not an a/c engineer or designer, but this much I know - mobile a/c requires average head pressures of about 200 psi to funnel a low pressure liquid that's somewhere around freezing (30 psi for R12; 28 psi for R134) into the Evaporator for vaporization. Idle and Low Speed operation uses fans to maintain the desired pressure and theoretically, it doesn't matter what you put in front of the condenser as long as you have enough air movement to maintain designed pressure/temp. However, the smaller R134 molecule tends to become more compact at higher temps (90 +) meaning that it can exceed design limits for pressure/cooling on those vehicles which use a pressure sensitive switch to control the fan(s); pretty much anything before the LT1 or '92. There isn't anything available on these vehicles to get the fans cranking at lower pressures to maintain system stability at lower speeds, so the only solution is to use less gas which at cooler ambients (below 70) will lead to increase cycling/more wear and tear, and in some cases - because compressor engagement isn't controlled by the ECM - poorer idle control.
Additionally, the car used to have a Z-52 fan in front which I had to remove for clearance reasons. (Hey, find a better place for a real air-oil cooler and air-tranny fluid cooler, I'm all ears. ) I'm sure the additional airflow it would add would have been helpful.
This is why I kept my A/C system on R-12 when I rebuilt it last year. Its been in the upper 90's with low 100's on the road around here this summer and the system works great.
As far as C4's having A/C problems, its reflective to remember that most of the C4 OEM A/C systems lasted 20+ years many with the original Freon charge.
Last time I checked they don't even sell the saft seals anymore.
If you can find'em post your source and part numbers for the standard shaft seal, case seals, bearings.
Use some penetrating oil on the hardware before you begin. You'll more than likely still need a 6mm allen attached to an impact gun to get the hardware off/out of the compressor case.
Nippo 10PA20C shaft seal kit is $21 or so at www.ackits.com - I wouldn't bother with the R4, though I'm sure there's a kit for it too.
Never had to use an impact wrench on a compressor. Shaft bolt is 10 ft/lbs and anything more has crushed the shaft seal. Manifold bolts are the same. Going ape on these aluminum cases will distort if not break parts, squish o-rings, etc.
Aux fan on these early Years isn't tied into a/c or even necessary, though to use it, you will need to splice the driven side of the Relays so that they're under control of the Pressure Switch. Also consider an alternator upgrade as both fans plus full Blower will overwhelm output and once it's below battery, everything will slow down and pretty much make the mod worthless; ie, it'll overheat and it won't be making cold air.
