Rebuild A/C compressor?
Old Jun 27, 2011 | 12:23 PM
RocketSled's Avatar
RocketSled
Originally Posted by dizwiz24
I recommend you do, with your AC, like you do when the cats get clogged up:
Remove the part for increased performance/
I yanked the A/C and installed an A/C delete pulley in '05 on my vert.
Never been happier.
Of course my thinking was 'its a vert, if Im driving it the top should be down at which point AC is useless'.
That's definately an option...it's just not quite so convertible with the hardtop installed. (a HELLUVA lot stiffer, tho)
I've seen the delete pulleys, look like something I can fab in the metalshop, too.
It's just that, dammit, that's all you SEE is old cars with dead (or missing) A/C.
Old Jun 27, 2011 | 02:12 PM
91kuhndog's Avatar
91kuhndog
Rocket.... you're only going to lose 15% of your cooling capacity by using 134 over R12. I found on my Grand Nat a couple years ago, I lost 4* at the vents when I converted to R134.... but that's your choice. Just remember..it's better to be cool with the windows up in July than to be cool sitting in 90* rush hour traffic (with the windows down)! Good Luck!
Old Jun 27, 2011 | 02:26 PM
RocketSled's Avatar
RocketSled
Perhaps it was a crappy conversion then as it's always been kinda wimpy after that.
Old Jun 28, 2011 | 11:49 AM
SunCr's Avatar
SunCr
Originally Posted by engle1147
I couldn't find the shaft seal on the site you listed only this stuff turned up on a search: http://www.ackits.com/merchant.mvc?
Was only talking about disassembling the 6mm allen compressor case bolts with impact tools - nothing more.
1st or 2nd page - Shaft Seals and Gasket Kits - about half way down: http://www.ackits.com/merchant.mvc?
Old Jun 29, 2011 | 12:28 PM
engle1147's Avatar
engle1147
Old Jun 29, 2011 | 07:28 PM
ca-wolf's Avatar
ca-wolf
Part SK-732N and KT-10PA20CN from centuryautoair.com
http://centuryautoair.com/mcart/index.cgi?code=3&cat=14
Old Jun 30, 2011 | 07:01 AM
91kuhndog's Avatar
91kuhndog
Rocket.... the key to optimum performance using R134 is to change the orifice tube and the drier when you change the compressor. I always pull a good -28 to -30 vacumn and let it sit to make sure it holds. While it's true R134 isn't as efficient as R12, I dont buy into the fact that a 134 system won't cool efficiently..... I cant recall which compressor your running, i have to guess a R4 because their 5x more prone to failure..... but if your running a Nippen-Denso, you should be able to get your system back to cooling without breaking the bank. I'm in the process of making an AC video for youtube....I'll post it on here....
