1987 Frame/Engine Ground wire?
Old Jun 29, 2011 | 05:25 PM
wammac's Avatar
wammac
Cruising
Default 1987 Frame/Engine Ground wire?
on my 1987 there is a metal shoelace kind of wire attached to my fram under the car on the drivers side. My dad says it is supposed to be connected to the engine also but currently its zip tied because i cant find where it is supposed to go. Anybody have any clue what im talking about and possibly where it goes on the engine?
Old Jun 29, 2011 | 06:09 PM
cadmaniac's Avatar
cadmaniac
If its the one I'm thinking of, it goes to a big grounding harness near the oil pressure sending unit. There is a 18 or 19 mm bolt holding it in.
Good luck.
Old Jun 29, 2011 | 07:10 PM
383vett's Avatar
383vett
Good luck.
It's near the oil temperature sending unit on the driver's side of the block in front of the filter. Mine has a 3/4" bolthead. There are 3 or 4 other wires that use that same ground.
Old Jun 30, 2011 | 12:53 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Old Jun 30, 2011 | 08:42 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
To 1987 Frame/Engine Ground wire?
