intake port design
Old Jul 3, 2011 | 10:39 PM
blackbear10's Avatar
blackbear10
Default intake port design
Hello all, I have an 84 and i took the intake manifold off today and could not believe my eyes. The intake ports are only 2/3 the size of the head intake ports. Is this correct? Who would design such a mismatch? If they wanted low end torque change the cam not the runner proportions.
Old Jul 4, 2011 | 12:35 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Get the grinder out and start grinding. In about 10 hours you will have a reasonably well flowing I.take capable of taking your car into the 13's. Yes, that is how it was designed from the factory, and low RPM ta was not the reason; emissions was the reason.
Old Jul 4, 2011 | 05:20 AM
jeffp1167's Avatar
jeffp1167
Why complain won't change the dual toilet bowl injection disaster under your hood. Dump the CFI and put a miniram or at least a 4 banger in and feel a instant power increase.
LU-5 or L-83 = complete lack of respect for power and only marginally better then what fred flintstone drove.
Old Jul 4, 2011 | 09:18 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
...and THAT was real helpful. Port it. Thoroughly. You won't regret it.
Old Jul 4, 2011 | 10:32 PM
cv67's Avatar
cv67
St. Jude Donor '05
Used to be a member here SHINOBI-X had a stock crossfire with fully ported base would run neck and neck with my 89 TPI on the track
All depended on who got the jump. Car ran well.
Old Jul 5, 2011 | 12:29 AM
jeffp1167's Avatar
jeffp1167
crossfire has no hope. I own one and they are dogs that can be outrun on foot face it they are a dinosaur of efi. You talk about port a cfi and it will run with a tpi, I call .... port a stock base of a cfi isn't got to make up the the difference of 40hp and what 40ft lbs of tq. face it cfi is good for 2 things .... a boat or a garbage can.
Old Jul 5, 2011 | 12:40 AM
87 vette 81 big girl's Avatar
Ron, the guy above your post is an expert cylinder head & intake porter.
He has been around for some time & is a very good wrench on all Musclecars including C4's
He has owned & raced many C4's including ZR-1's.
I believe what he said about home porting a 1984 CFI intake & getting to perform nicely for torque an acceptable HP on the street.
Won't make 800 HP with no power adders.
But should make close to 300 flywheel horsepower with a decent combo on a 1984 Vette 350 shortblock/ longblock.
Just my 2 cents.
Brian
Old Jul 5, 2011 | 01:13 AM
383vett's Avatar
383vett
Just my 2 cents.
Brian
Hey Brian. When I had my crossfire, I did a lot with it. Ported the intake and heads, larger throttlebodies, cam, headers, etc. I can't remember what the final combination ran, but I'm not sure I picked up 95 horsepower to make it to 300. Willie
Old Jul 5, 2011 | 02:59 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
All ^That^ proves is that YOU failed with that combo. NOT that it's _______ (what ever insulting phrase is in vogue for you today). I've read your posts before. I know that you failed to get a CFI car to perform. Point noted. I and others have succeeded, however, and it most certainly CAN pick up 40/40 from porting and "free mods" (tuning) quite easily.
Brian is right. A WELL ported intake CAN support ~300 fwhp on a 350 bottom end.
Question (for anyone) About how may fwhp does it take to make a 3300 lb car go:
*14.5/95 in the 1/4?
*13.8/102ish in the 1/4?
*13.2's/105ish in the 1/4?
Those are times that I've ran myself, or seen first hand through a ported stock intake. The first time was an UNported, stock intake on stock 305 -rated at 170 hp from the factory. Takes about 220hp to go 14.5/95 in a 3300 lb car.
Point is, a person (obviously not jeffp1167) absolutely CAN make big gains on a CFI car, with little to no costs. The big gains come easy partly b/c the starting point (stock configuration) is so poor. Low hanging fruit, I like to call it.
-Tom
Old Jul 5, 2011 | 05:29 AM
cv67's Avatar
cv67
St. Jude Donor '05
x
im not arguing juat saying what ive experienced. Somewhere i still have some timeslips from LACR- you can find him on youtube chieffatnutz maybe he will pipe in. cant remember if he had 307 or 3.54 would just weeze by him towards the tail end run after run unless he got the jump
Edit from post below
You port that intake right you will see night and day gains. Someone didnt do the job correctly if you didnt feel anything.
Old Jul 5, 2011 | 07:38 AM
It don't matter for you no longer Willie...........
"You are in an Elite Wheel Standing Drag Racing League" anyhow.
I was just kidding a few nights ago.
Need to be near 100 % crazy to launch a car down the 1/4 mile and stand it on the rear bumper & drag it for 200 to 300 feet.
Whenever I see your 84 c4 pics of it launching with a wheelstand I have Vivid flashback memories of "Frankie" and his Bright Corvette Red 1969 BBC Camaro.
There are pics out there of him getting all 4 wheels off the ground on launch.
Stood the car up past the rear bumper.
A engine block freeze popped out on launch and spilled water- coolant all over the track and under the rear tires.
I was there..........the adrenaline rush of the crowd & myself was better than any rock concert i had been to in my entire lifetime.
Byron World Wheelie Contest,
Even if you leeve your car at home Will,
You need to attend at least once & watch.
Beyond words some years what you see in person.
Brian
Old Jul 5, 2011 | 02:14 PM
84cfi's Avatar
84cfi
I had a fully ported intake on my crossfire, it was a little disapointing. It doesn't work well with a stock setup, you have to charge the convertor, heads exhaust to see any improvement. I switched to a renegade intake now it runs much better.
Old Jul 5, 2011 | 02:33 PM
cv67's Avatar
cv67
St. Jude Donor '05
CFI-EFI was running pretty strong times with his, stock save for a converter and heavily ported CFI intake.
Old Jul 5, 2011 | 02:47 PM
84cfi's Avatar
84cfi
You need a higher stall convertor with a ported intake or it will bog off the line.
Old Jul 5, 2011 | 03:03 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Originally Posted by 84cfi
a fully ported intake...doesn't work well with a stock setup, you have to charge the convertor, heads exhaust to see any improvement. You need a higher stall convertor with a ported intake or it will bog off the line.
That is either a bald-faced lie, or complete and total ignorance. It is "made up" and not true. I have been there/done that and the quoted poster has not, inspite of what he claims. Porting a stock intake will result in no such "bog".
CFI-EFI (mentioned above) has also gone down the ported intake road on a box-stock engine, and was generously rewarded by his results, dropping ~.7 seconds off his ET at the track...on the stock "convertor, heads exhaust".
There is absolutely NO "down side" to porting that intake; all you get is gains, with no losses anywhere. It is a win-win "mod".
Old Jul 5, 2011 | 04:24 PM
84cfi's Avatar
84cfi
You can go ahead and port your intake. It will be better than stock but be prepared to do a few other mods to help it along. Porting alone will not do much. Advance your timing raise your fuel pressure to 15 psi order a higher stall convertor and be careful not to go through the floor of the ports it is about 3/16 of an inch thick. If you look on this forum you will find some info on porting or google it. You might find a ported intake for sale maybe or you could buy a new intake etc x-ram, renegade. If it is legal where you live you could remove your cat that helps.
Old Jul 5, 2011 | 07:21 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I think that most will agree that .7 is "much" for a single mod that is essentailly free. Xram isn't a great option Renegade would be if/when you can get one.
To intake port design
Old Jul 6, 2011 | 01:57 PM
84cfi's Avatar
84cfi
The before run must have been a very poor run. What was your times before and after ?
Old Jul 6, 2011 | 02:29 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Right. They were better than most stock or stockish CFI runs, in spite of the elevation.
There were HUNDREDS of "before runs"...many of those ultimately contributing to the earning of two Wally's.
Not me or my car; the late, great, CFI-EFI. You already know that though...didn't you Nelson? I mean, 84L83/85L98 or whatever.
Old Jul 6, 2011 | 03:24 PM
84cfi's Avatar
84cfi
What did this CFI in question run in stock form? Do you know the 1/4 mile time?
