L98 fuel issue
Old Jul 6, 2011 | 02:01 AM
SSG_G's Avatar
SSG_G
2nd Gear
Default L98 fuel issue
I Have a 1990 Convertible that will start and run until i get to about 4000 rpm then dies, I have already changed the fuel pump but cant figure out where to check next. Any help would be appreciated.
Old Jul 6, 2011 | 02:17 AM
Cliff Harris's Avatar
Cliff Harris
You need to get a fuel pressure gauge on the fuel rail. You can drive with it attached and see what's happening. It's possible the fuel filter is clogged.
You might have ignition problems. You need to isolate the problem before you can fix it. Check the fuel pressure first.
Old Jul 6, 2011 | 02:24 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
To L98 fuel issue
