Turbo Question
Old Sep 8, 2011 | 08:43 PM
  #41
yedister's Avatar
yedister
Originally Posted by lcvette
With regards to this you are correct, but improperly or too small of a turbo and boost pressure will bleed down in the upper RPM's. so while you are correct in saying flow > boost, it is important to remember that boost equals the ability of the compressor to continuously feed flow to the motor. based on the combination you are showing, 67mm units in my opinion will be perfect with alot less lag than 76's, for drag, unless you are just trying to run for fun, i don't think twins fit into many classes so you wouldbe looking at either an 88mm to run in 275 competitions or 275X would allow you to jump into a 106mm single.
for a fun street car, the 67's would be the hot ticket!
Chris
Not a class car, having a car that need to be towed to a track to enjoy driving it is not for me, might as well be a boat. Fun street car is what I am after. Thanks for your input.
Old Sep 8, 2011 | 09:01 PM
  #42
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Are you backhalf'ing the car?
a D44 won't take the torque
Old Sep 8, 2011 | 10:43 PM
  #43
yedister's Avatar
yedister
Planning 9 inch with a 3 Link/Watts Linkage, 4L80E transmission. I would love to put a 6L80E but, there is no aftermarket controller as yet for it. I'm not sure if it will fit. When I have the exhaust redone in about 2 months, some measurement will be taken.
Information I found:
Trans.....Overall Length.....Length to Mount.......Weight
4L80E.......32-5/8................26..................... .174 dry
6L80E.......29-1/4................25-3/4.................213 wet
Old Sep 8, 2011 | 10:49 PM
  #44
AKS Racing's Avatar
AKS Racing
Originally Posted by yedister
Yes I was thinking that, thanks for busting my bubble
Why do you not want to cut the hood. Mine is done. When done correctly, it is very neat and clean. You are just cutting the underhood support, not all the way through the hood skin.
F2R fits without cutting past the supports.
Old Sep 8, 2011 | 10:53 PM
  #45
yedister's Avatar
yedister
Picture please
Old Sep 9, 2011 | 09:10 PM
  #46
yedister's Avatar
yedister
Originally Posted by AZ86Vette
Thank you for the info. More info the better! My car is setup correct it's a l98 700r4, so in the future I should look into a tpis miniram.
Oh and thank you for clearing up the FMU...
Im hoping to get parts together in the next month,
Kris
I would like to hear more about your setup
Old Sep 10, 2011 | 03:42 PM
  #47
lcvette's Avatar
lcvette
Yedister,
being you will drive the car mainly on the street with a few top speed events, i would lean towards the 67mm's, but thats me, i have done the bogger turbo laggy setups and they are fun but the lag is a killer and it requires you turn the motor quite high in the rev range. 67's would be hard pressed to get near 1800rwhp, but would likely hit the 1500rwhp mark. that is a ton of power to play with with a VERY broad power band hitting early on in the rev range.
to hit the 1800rwhp mark i agree that twin 76mm units would be the right choice if twins were what you wanted, for that gopal i would probably start leaning toward a big single. and keeping AC becomes a true challenge going to a single that large. It can be done but there would be significant work to the frame and front cross member to be done. I will see how a pair of 76's looks down low in the next week or so while I have mine in the air putting the 67's on. I am using smaller compressor housings to try and gain some room and on 76's that would kill the benefit of the larger wheel.
from a quick look I know the following to be a reality, if you go with midframe 76mm units, the factory motor mounts will not work, a custom motor mounting solution would be required as well as a customer tubular crossmember and the use of coil overs in the front to be able to remove the front leaf spring. I feel confident with these changes the upper portion of the accessory bracket could be maintaints for AC. a liquid to air intercooler setup would be required for the best efficiency as there simply wouldn't be enough room for the correct sized air to air core and the coolant and AC radiators. custom shrouding would also be required. again very possible but it would require significant work to accomplish.
I amdire your goals, I would say we think very similar in terms of power lol.
maybe we can talk some more about it once I begin putting the 67's on my 355cid setup. should be starting it mid next week!
Chris
Old Sep 11, 2011 | 09:23 PM
  #48
yedister's Avatar
yedister
Yedister,
Chris
My engine will have about 100 cubic inch more. I will be waiting to here about your twin project. I am planning on running air to air inter cooler and alcohol injection with Wilson throttle body when I turn the boost up, the intake will run the fuel.
This is the Wilson Throttle Body
Old Sep 12, 2011 | 07:18 PM
  #49
Mike in Boston's Avatar
Mike in Boston
Default Self contained oiling?
Is it possible to use a self contained oiling setup when using a rear mount turbo configuration? Basically, an oil tank, electric pump and other stuff all contained in the spare tire area?
I've never seen it done but I don't get out much
-Mike
Old Sep 12, 2011 | 09:26 PM
  #50
yedister's Avatar
yedister
-Mike
Please take a look at these;
http://www.yellowbullet.com/forum/sh...light=corvette
http://www.yellowbullet.com/forum/sh...d+oiling+setup
http://www.yellowbullet.com/forum/sh...oiling%2Bsetup
Old Sep 12, 2011 | 10:03 PM
  #51
Mike in Boston
Wow, those links are fantastic! I've never heard of an oil-less turbo. I guess a lot changes when you spend 3 years chasing a tiny human around the house and take a break from the car scene.
Old Sep 13, 2011 | 06:22 AM
  #52
yedister's Avatar
yedister
Chasing tiny human around for 3 year is the why we can still fit inside the corvette. There are so many changes in the Automotive world, you can thank the import guys for lots of the changes in turbo technology. The first time I heard/saw a Comp Turbo was at a NOPI event a few years back.
Old Sep 16, 2011 | 12:37 PM
  #53
Teme_76's Avatar
Teme_76
I have my Oil and transmission cooler back there also.
How well this setup will work on street car? I have had same ideas....
Old Sep 16, 2011 | 08:31 PM
  #54
yedister's Avatar
yedister
It works great, I have the fans set as pullers and there is space around the cooler fins so I can get air flow through them with ease.
Old Sep 20, 2011 | 12:43 AM
  #55
Teme_76's Avatar
Teme_76
Great! How do you control your fans? Thermostat in oil line?
Old Sep 20, 2011 | 02:35 PM
  #56
yedister's Avatar
yedister
DFI Gen 7 plus a thermostat
