Best replacement headers
Old Apr 25, 2002 | 12:05 PM
Corvette0096's Avatar
Corvette0096
Default Best replacement headers
What is the best fitting headers for a 85 vette? With the air tubes. And what "Y" pipe? I have the 4 bolt converter. I have the angel plugs in it now to.
Thanks in advance.
Old Apr 25, 2002 | 12:11 PM
scorp508's Avatar
scorp508
Easiest to drop right in would probably be Hooker 2149 headers. They are 1.75" primaries to a 3" collector and are coated w/ emissions hookups.
Give Chris K. a call at the # below. :yesnod:
p.s.
These are mine...
[Modified by scorp508, 11:11 AM 4/25/2002]
Old Apr 25, 2002 | 12:47 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: (scorp508)
Scrop, I guess you have angled plugs too; how will #1 & #7 clear the headers?
Do you see any problems with wires touching header tubes or maybe have to use short spark plugs?
Old Apr 25, 2002 | 12:48 PM
scorp508's Avatar
scorp508
Fastguy dropped a set onto his '88 a couple of weeks ago and there were no sparkplug issues to be seen. In fact it looks like a dream to change the plugs now. :)
Old Apr 25, 2002 | 01:12 PM
Corvette0096
Default Re: (65Z01)
There any issue with the brackets? Ac, alternator?
Old Apr 25, 2002 | 01:17 PM
scorp508's Avatar
scorp508
This seems to be different over the years. It appears the alternator is going to BARELY fit, or not fit. :( I think the AC should fit for pre 88. Not sure.
Old Apr 25, 2002 | 01:57 PM
65Z01's Avatar
65Z01
The A/C wouldn't bolt up on an '88 without using a stud and standoff as the OEMs have standoffs welded to the header flanges.
Old Apr 25, 2002 | 02:11 PM
QuikKev's Avatar
QuikKev
8th Gear
what would be the best 50 state emissions legal headers?(for an 86) I live in California so unfortunately long tubes are not an option :(
Old Apr 25, 2002 | 11:57 PM
corvette1990's Avatar
corvette1990
Default Re: Best replacement headers (corvette0096)
I used the TPIS Long coated headers, but needed a muffler man to make the Y pipe work. They are working great, and all the emissions stuff is hooked up. Just remember to wrap everything in silver protective wrap. Like starter, and egr pipe, etc, and route wires far as possible away from melting pipes.
To Best replacement headers
