PKE programming help.
Old Jul 9, 2011 | 12:14 AM
93sandiego's Avatar
93sandiego
Default PKE programming help.
I just got a new transmitter for a 93 Corvette. Did the Trip/ODO twice and then pressed and held the fuel/info button while the transmitter was about 20 feet away. The problem is that when i turn the car to the off position the PKE light goes out and does not blink. I pulled the fuse and turned the key to the on position then removed the key and still the same thing. I bought the car used and never had a transmitter before. Any ideas?
Old Jul 9, 2011 | 12:49 PM
93sandiego's Avatar
93sandiego
I dont know if this has anything to do with it but when i was programming it the chime started to die and now you can barely hear it.
Old Jul 9, 2011 | 05:06 PM
markKlein's Avatar
markKlein
Chime? What chime? The door open chime? Nothing will go well on a C4 if the battery is low. Make sure it is charged well and go through the procedure with the door closed. Might not matter, but you can start there.
Or do you mean the key-in-ignition chime? You might try holding the key firmly in the slot so it is not easing out of the slot enough to maybe show it as not present anymore.
Oh, check all related fuses, should be 26, 40 and 42, if I remember right.
Old Jul 9, 2011 | 05:30 PM
pcolt94's Avatar
pcolt94
The chimes do go bad and is not related. I would have to ask if the main battery in the car has a good charge on it and is in good shape. Does the car start OK?
If you pull a fuse out all bets are off and advice is non-valid. When you turn the key to the OFF position the PKE light should start to flash. The only problem I am familiar with is that there is a contact in the lock cylinder for the PKE. If that contact is bad then I don’t think you will be able to program it.
Other than that the PKE module could be bad. But before you go there I would check those other items.
Old Jul 9, 2011 | 05:36 PM
markKlein's Avatar
markKlein
You said you removed the key. You aren't removing the key are you? It is supposed to stay in the ignition.
Old Jul 9, 2011 | 08:21 PM
93sandiego's Avatar
93sandiego
No i leave the key in on the off position. The horn does beeb and the drivers door locks when i walk away so i think the system works, even with the PKE fuse pulled out. The car starts fast but has sat for a week i will check the other fuses and take it for a ride. I just cant get it to blink in the off position. hmm
Old Jul 9, 2011 | 09:31 PM
Charleston2012's Avatar
Charleston2012
My 93 always has issues. It works, but it is slow to register.
Have you been able to turn the alarm off with the Key Fob?
Old Jul 9, 2011 | 11:42 PM
93sandiego's Avatar
93sandiego
ok fuses checked good. hmm when i turn the car off it beeps the horn and the door locks. So i think the PKE works just cant get the light to flash to program the remote
Old Jul 10, 2011 | 09:45 AM
markKlein's Avatar
markKlein
OK, now I am really confused. If it locks when you walk away what is the problem? Sounds like it is already working. What does it do when you walk back to the car?
Old Jul 10, 2011 | 11:40 AM
pcolt94's Avatar
pcolt94
93sandiego - Not sure if you actually understand how the key FOB system works. Under normal circumstances as you walk up to the car, the doors (or door) unlocks automatically. And when walking away it locks automatically. Unlike other key FOB systems, YOU DO NOT PUSH A BUTTON TO UNLOCK (or lock) THE DOOR.
It sounds like it may already be programmed. It is a possibility you got it programmed but did not realize it. (This is what is confusing Mark).
Old Jul 10, 2011 | 12:39 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Confusing me too. I am far from an expert at troubleshooting these things.
But if the door is locking and you hear the horn beep as you walk away, then the FOB has to already be programmed.
Old Jul 10, 2011 | 01:38 PM
93sandiego's Avatar
93sandiego
Ya im confused also becouse i have not put the FOB on the key ring yet and it was doing this when i was out in town and the FOB was at home.
Old Jul 10, 2011 | 01:52 PM
markKlein's Avatar
markKlein
"Ya im confused also becouse i have not put the FOB on the key ring yet and it was doing this when i was out in town and the FOB was at home."
First things first, Pcolt and Rolla are right, make sure you read the owners manual and understand how it is supposed to work.
If it is doing this with the fob nowhere in the area then something really wierd is going on. I'm short on ideas, if I were you I would be searching the car for a hidden fob. Come to think of it, that could be why the light doesn't blink, maybe it won't if it detects an active fob in range. I'm not sure how long you have had your 93, in a 95 there is a storage area behind the pass. seat, and a hidden compartment under the elbow rest of each door. Check under the seats, everywhere. That is the only thing I can think of that might explain what you are describing.
Old Jul 10, 2011 | 02:13 PM
93sandiego's Avatar
93sandiego
Thanks will do that.
Old Jul 10, 2011 | 08:06 PM
pacat's Avatar
pacat
Default PKE article in Sept. issue of Vette mag.
Pick up a copy of the September issue of Vette magazine (I just got my copy in the mail, should be on news stands this week). Starting on page 16 there is a 3 page write up on the C4 PKE system on how to program it. Very good article. Good luckJ
Old Jul 10, 2011 | 09:37 PM
pcolt94's Avatar
pcolt94
Owners manual for a 96 but is good for all years PKE operation.
Starts at page 2-4.
http://www.gmpartshouse.com/download...96corvette.pdf
Old Jul 12, 2011 | 09:00 AM
markKlein's Avatar
markKlein
Any update on this?
To PKE programming help.
Old Jul 12, 2011 | 07:57 PM
93sandiego's Avatar
93sandiego
sorry out of town until friday. I did search the car except for under the arm rest didnt see that part. enen if a fob was hidden in the car wouldnt it need to move away from the car to activate?
Old Jul 13, 2011 | 09:30 AM
markKlein's Avatar
markKlein
No, the combination of the fob not moving and the key removed could trigger the PKE module to lock the car. The fob does not transmit a signal to lock the car, it is constantly transmiting a signal to not lock the car. When the fob stops moving or you walk away and it moves out of range (and the key is not in the ignition) then the receiver locks the car (that is why you probably shouldn't ever leave the keys in the car when you get out).
That is the best explanation I can come up with for why the car would lock itself when you turn the key off and the fob is nowhere around. If there is no hidden fob, and your new one is not near the car, then the only thought I have is some sort of (electrical Gremlin) malfunction in the PKE receiver. Those are expensive and not easy to remove and replace. Sorry I couldn't help more, maybe someone else has some better ideas.
Old Jul 13, 2011 | 09:41 AM
toptechx6's Avatar
toptechx6
Sorry, but I just have to comment concerning the article you mentioned. On the very first page of the article is says that the C4 PKE system can be switched from passive to manual mode and that when in the manual mode the system allows you to "unlock the doors as you would with any other key fob."
That information is WRONG, the PKE system in our cars will NOT function in manual mode.
Believe the balance of the article at your own risk, something tells me the writer failed to do his research.
