1987 no start.
Old Jul 9, 2011 | 12:57 PM
staugur's Avatar
staugur
Default 1987 no start.
Hi Guys, where are the brilliant minds? Car just decided it didn't want to start.Turns over fine,got spark,47psi fuel pressure but injectors not grounding out. squirt of easystart and she'll go so obviously it's an injector problem.Question is,has the ECM gone bad on me? Some local shop said it could be the ignition module but I don't think that would stop the injectors from firing,or could it? The only code showing is a 46-vats problem but that's because I bypassed it years ago. Anyway,anyone got any ideas?Don't want to spring for a new ecm if it's something else.
Old Jul 9, 2011 | 01:45 PM
joe paco's Avatar
joe paco
ecm uses pulses fromm the rotating distrubutor to signal injectors. not familiar enuff to tell you more. spark has to be strong and blue, rather than "spark." I would try removing the inj fuses, one at a time, in case one bank had a def injector, which MIGHT signal ecm to shut down injectors if one injector is shorted. should start with one bank firing.
there are experts on here, no question. give 'em time.
Old Jul 9, 2011 | 01:53 PM
joe paco's Avatar
joe paco
may have misread your post. does it "go: and run fine, or shut off when fuid is gone? also, TPS signal is used by ecm, if not correct it shuts off fuel assuming it is flooded. you have tried the pedal to the metal I guess?
Old Jul 9, 2011 | 02:11 PM
staugur's Avatar
staugur
Default no start
Quits as soon as the ether is gone.I've put a noid light on several of the injectors and they don't flash when I crank the engine. There is always a 12volt pos to the injectors and the ECM grounds them to fire them.For some reason mine aren't grounding. Anyone know if a bad prom could do this?
Old Jul 9, 2011 | 03:12 PM
3D87C4's Avatar
3D87C4
These help at all? (Chart A3 page 2 from FSM)
http://i1116.photobucket.com/albums/...s/6e3-A-16.jpg
http://i1116.photobucket.com/albums/...s/6e3-A-17.jpg
Old Jul 9, 2011 | 04:09 PM
staugur's Avatar
staugur
Originally Posted by 3D87C4
Thanks for that. I have lights on both terminals which seems to indicate either a short in the injector harness or a bad ecm.resistances seem OK.Having checked all that of course the damn thing started.!!!Now I'm in that unenviable situation where I just can't trust the beast! I hate intermittent problems,much better to have it fail completely.Looks like a new ECM is on the cards.
Old Jul 9, 2011 | 06:25 PM
3D87C4's Avatar
3D87C4
You're welcome.
Reading through note 3 on page 16, I wonder whether the fact the problem is intermittant implies a short to power or loose pins in the connectors?
I speculate an ECM problem (with no moving parts) would be less likely to be intermittant than a wiring fault.
Just a thought---I have no experience actually working on this.
Old Jul 9, 2011 | 08:05 PM
staugur's Avatar
staugur
You're welcome.
looking at the diagram on page 16 it appears to show a switch to ground in the ecm to fire the injectors,perhaps that's failing.Don't know either!When it comes to computer crap I'm lost.Years ago,back in the UK ,I used to build race engines for Jags with not a chip in sight! Anyway, I can throw in a refurb for $100 and see what happens. Too many variables at the moment for my little mind to comprehend.
Old Jul 10, 2011 | 12:22 AM
jfb's Avatar
jfb
When it won't start. THAT is the time you start diagnosing where the problem is. The ECM requires reference pulses from the distributor in order to pulse the injectors. See if you have pulses on the purple/white wire out of the distributor during cranking. If you don't, then you need to find out if the spark module inside the distributor is good and also if the pickup coil is good. Some parts places can test the spark module, although a member here says their test isn't reliable. You check the pickup coil with an ohmeter. I'll look and see if I can find the correct resistance you should measure. Of course, intermittent problems are the hardest of all to find!
Old Jul 10, 2011 | 09:09 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Ignition module supplies reference signal to ECM. If it's not there, no injector pulse.
Normal, 12v will go through injector coil to neg side, until the ECM supplies ground.
AGENT 86's Avatar
AGENT 86
Check your 4 pin connector at base of dizzy, maybe it's loose or dirty.
Old Jul 10, 2011 | 11:47 AM
jfb's Avatar
jfb
GM says the pickup coil should measure between 500 and 1500 ohms.
Old Jul 12, 2011 | 11:02 AM
staugur's Avatar
staugur
Well,it seems my ECM is shot after talking to the guru at Zip.And yes,a bad ignition module could cause the problem but there's a simple test I didn't know about so I'll pass it on for what it's worth.Watch the tach when you crank the motor.If the module is good it should show 200/300 rpm when you crank.No rpm= bad module.. $109 exchange for the ECM so not too bad. Thanks for the suggestions guys.
Old Jul 12, 2011 | 08:27 PM
jfb's Avatar
jfb
Another satisfied customer!
To 1987 no start.
