Speedo quit working
Old Jul 10, 2011 | 09:57 PM
89vette's Avatar
89vette
Default Speedo quit working - UPDATE
So here's the problem of the week. No speedo signal at the dash or ECM. So I pull the VSS and it looks good. I looked in the VSS hole and the teeth on the worm gear look good. However, I can spin the worm gear with my finger. I've never had the tailshaft off before but I would think thar the worm gear should not spin. Anyone know this before I pull the tailshaft?
UPDATE:
I had a closer look this AM and the drive gear is NOT spinning on the output shaft. It must have felt that way when I was attempting to turn it. Also my VSS is generating an output voltage so the problem is between the speed sensor and the dash.
And to think for a minute I thought this was going to be easy!
Old Jul 10, 2011 | 10:40 PM
cadmaniac's Avatar
cadmaniac
You can check the pulse of the VSS with a multimeter. I checked mine and it will register a pulse signal. I used plastic jumper connectors from the speedo wires out of the transmission to make long wires I could use to test, jacked up the car, set the rear on the frame on jackstands and got the tires up to what would be maybe 5-8 mph. The VSS registers a signal in the smallest of measurments I believe of voltage, but cant remember. Google "How to test a Vehicle speed sensor" and it will tell you how to set your multimeter.
My VSS puts out, but my speedo doesn't work...wish I could figure out why too...
Good Luck!
Old Jul 11, 2011 | 08:40 AM
89vette's Avatar
89vette
VSS Verifed working and the gear is NOT spinning on the shaft. On to wiring issues.......fun.
Old Jul 11, 2011 | 10:37 AM
engle1147's Avatar
engle1147
UPDATE:
There is a very large multiple pin connector on the firewall just behind the battery that can collect water if the seal is old/busted. The wire from the VSS goes to - through that plug then on to the cluster.
Old Jul 11, 2011 | 10:39 AM
89vette's Avatar
89vette
Thank you. Maybe it has something to do with my tach's erratic signal too even after replacing the tach filter. I suspect it's the connector that plugs into the right side of the gauge cluster.
Old Jul 11, 2011 | 10:53 AM
engle1147's Avatar
engle1147
The tach wire in the firewall connector is one of the pins near the bottom of the connector and it is usually where h20 collects first and causes an issue. The big firewall connector is a real bear to get to, remove, clean, reinstall and reseal. Take your time with the project.
Speedo and tach connections @ the cluster are in the same connector (the larger of the 2).
Check the ground cables (- battery cables) lug(s) on the engine block (big wire directly bolted to the block above the oil temp sender) and on the tranny bell housing to ensure that they are good-n-tight. Loose grounds will sometimes give you wacky problems such as your mentioning. Keep us posted.
To Speedo quit working
