what is that ?!
Old Jul 11, 2011 | 03:46 PM
ndanl's Avatar
ndanl
Default what is that ?!
it looks like a sensor, it has two wires connected and it is located near the distributor, and I think it is leaking oil badly ?
car is 1991 corvette L98
thanks,
Dan
Old Jul 11, 2011 | 03:53 PM
oldalaskaman's Avatar
oldalaskaman
oil pressure sending switch?
Old Jul 11, 2011 | 03:56 PM
383vett's Avatar
383vett
Sounds likely.
Old Jul 11, 2011 | 03:57 PM
ndanl's Avatar
ndanl
aha, then I think I need to take the plenum off to reach for that sender do I need a gasket or just try to tighten it harder ?
Old Jul 11, 2011 | 04:05 PM
Calderone's Avatar
Calderone
i think you need to remove the distributor only , can you take pics ?
is this the part we are talking about ?
check where the leak is coming from, those are two sensor in the fitting
Old Jul 11, 2011 | 04:09 PM
ndanl's Avatar
ndanl
sure, tomorrow because now it's night here and dont have enough light
thanks
Old Jul 11, 2011 | 04:11 PM
Calderone's Avatar
Calderone
From another post :
Originally Posted by Calderone
Here shown with pressure switch
Old Jul 11, 2011 | 04:47 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
If it's leaking around the threads, remove, recoat threads, and re-install. I like teflon sealer myself. Oil-approved silicone will work as well.
More often, the sensor itself fails and causes the leaks. That would warrant replacement.
DS Valve cover leaks are sometimes mistaken for oil sensor leaks and visa-versa. Be sure of your source.
Old Jul 11, 2011 | 04:49 PM
joe paco's Avatar
joe paco
thanks
your 91 is not exactly like that. I have 91, and can get to it without removing plenum, although it is under plug wires and a wire bundle. one sender goes to gauges and has one wire, this one is below that one, two wires, on same manifold
joe.
Old Jul 11, 2011 | 05:19 PM
joe paco's Avatar
joe paco
joe.
2 pics of what you describe. the line metel to left is brake vac line, can be removed from plenum with 5/8 wrench, pull out of the way. also plug wires and GENTLY move the wire bundles.
as the man said, make sure you are sure where the oil is coming from, clean if off with a brush and some gasoline, wipe it clean, let it leak some more. THEN spend a couple hours removing the switch.
joe
To what is that ?!
